Old 10-29-2005, 12:51 AM
Alanpreiss Alanpreiss is offline
Question 3.0 liter caravan coolant leak
I have coolant pooling in the V of my 3.0 liter block under the intake manifold. If the water pump is failing can coolant get to the V even if the water pipe O- rings are not leaking? Has anyone experienced a similar situation?
Old 10-29-2005, 01:18 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: 3.0 liter caravan coolant leak
Theres actually a hole then when ur pump starts to go bad (the seals i believe), it starts to leak out of that hole. I forget exactly what its called but if its leaking from your water pump, you need to replace it.
And yes, some coolant will still get through but only until you run out which doesnt take long.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 10-29-2005, 06:08 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
In my experience, coolant that pools there comes from a leaky upper radiator hose connection at the engine, or a leaky thermostat housing gasket.
