Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-28-2005, 11:01 PM
mokgiahoa mokgiahoa is offline
Replace Throttle Body for '90 Cutlass Supreme
I have the 90 Cutlass Supreme V6 3.1L
I want to replace the Throttle Body but I don't know which one I should buy because the '90 one is too old
Anyone know what latest year have the same part that i can use
thank!!!!
Old 10-29-2005, 07:04 AM
ctesla's Avatar
ctesla ctesla is offline
hey Arlington,
welcome to AF.
throttle body units are mechanical.
return spring butterfly(throttle plate) and this is basicaly it.
the TPS bolted to one side is a sensor that may need swapped out.
you can buy intake air cleaner for $2 per can and spray this down the TBIs "throat" to clean it out.
if you want a new one, the Tomco# 8-103 can be ordered from O'Reilly Auto Parts (Hi-Lo) for $300.
the air cleaner temp sensor is only $15. through Borg Warner, and can also be changed, but if the TBI is still working, no need to swap out.
injectors usually start going bad first.
you could find a rebuiler or shop that modifies or services TBs or carbs.
they can usually tear down and rebuild for $100 or so (parts and labor), and use a kit to service any moving parts and/or gaskets.
if you are still looking to find a spare TBI from a salvage yard, most mid- 90s GMs with 3.1 or 3.4L might be interchangeable, just check mounting and electrical sensor hook-ups.
hope this helps,
chris
nrt racing
