Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 10-28-2005, 09:49 PM
sly_ww sly_ww is offline
tire advice
ey guys! i have a 31" tire mounted on a 2006 tacoma prerunner. don't wanna lift the truck for now for warranty reasons but i've noticed some rubbing when i do sharp turns. will that be no big deal for the frame of the truck?
thanks!
Old 10-29-2005, 02:21 AM
03TRDTacoma's Avatar
03TRDTacoma 03TRDTacoma is offline
Re: tire advice
no it should be fine, it will just leave wear marks. u could even ask the dealer if they would do a 2" lift or something of that nature.
2004 Toyota Tacoma 4x4
1990 Eagle Talon TSi AWD
2002 Suzuki GSX-R 600
Old 10-29-2005, 06:56 AM
Flash75 Flash75 is offline
AF - Advisor
Re: tire advice
I don't think wheel rubbing should be ignored, as a minimum it will rub the paint off the frame and you will have premature rust. How sure are you that the tires cannot get cut by some sharp part of the frame? It could damage your truck and it may create a safety hazard. My 2 cents.
Clifton
Old 10-30-2005, 12:19 AM
GlocksRock GlocksRock is offline
Re: tire advice
Didn't that truck come with 31" tires? 265-70-16's right, and they rub? That doesn't sound right. Are they on aftermarket rims or something? Cause the stock tire size on stock rims should not rub, unless your doing something a little crazy.
Old 11-06-2005, 10:32 PM
Bryan70usa Bryan70usa is offline
Re: Re: tire advice
the metric version (265 70 16) of the tire is slightly smaller than the u.s (31")
Old 11-07-2005, 12:02 AM
Re: Re: Re: tire advice
Not really. If you go to tirerack and check out tires that offer both sizes, such as the Dueller Revo or Yokohama Geolander A/T, the 31x10.5 is slightly smaller. Either way the difference is miniscule and both sizes are basically the same outer dimension.
