Old 10-28-2005, 09:30 PM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
Question 92 Rear-Drum Brakes
Does the parking brake cable always connect to the primary shoe?
Just in case it helps this is the passenger side assembly. The reason why I ask this is because the passenger side assembly is fully expanded(I have a hard time getting the drum off) and catching better then the drivers side.
http://www.cardomain.com/ride/631458
_______________
92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat
Old 10-28-2005, 09:37 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 92 Rear-Drum Brakes
I had the same problem with Kasey's car. The drum was sticking. Your best bet for getting it off is using a carpenters pry bar with the angled end. stick it in the drum groove while hammer the other end from under the car and start in one spot and work in a circle. Wack at it hard. Your not going to crack the drum cover. Trust me. Should work its way out even if its on there pretty good. Just make sure there is no ring or pin holding the drum on GM sometimes used those.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-28-2005, 09:47 PM
J.Cutta's Avatar
But why is it expanding more then the drivers side?
_______________
Old 10-28-2005, 09:53 PM
FormulaLT1's Avatar
Fight the powwa!!!
They do that. The brake fluid pressure is never the same exact at all hoses and the shoes don't wear completely even at both wheels. So thats to be expected. Kaseys car was the same exact thing. I took his passenger side off by hand and his driverside I had to wack 20 - 25 times with a pry bar and a small sledge hammer to get off. Thats how they are sometimes.
ct91rs ct91rs is offline
Re: Re: 92 Rear-Drum Brakes
Couldn't you tighten up the self adjusting screw?
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson
Old 10-29-2005, 11:47 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Originally Posted by FormulaLT1
Wack at it hard.
heh....eww.
