Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-28-2005, 07:37 PM
WILLCAR WILLCAR is offline
Question No Brake Lights
Need Help Trying To Figure Out Why There No Brake Or Hazard Lights
Old 10-28-2005, 10:16 PM
arpco arpco is offline
Re: No Brake Lights
What Year?????????
Old 10-29-2005, 03:16 PM
Fullyinvolved Fullyinvolved is offline
Do your dashlights work? The reason I ask is because the same fuse that controles your dashlights controles your taillights. Sounds funny, but it is a good way to let you know something is burned out.
Never argue with an idiot. They will bring you down to their level, and then beat you with experience
Old 01-06-2006, 03:03 PM
TJfishin TJfishin is offline
Re: No Brake Lights
Do your turn signals work? If it's not a fuse>
My flashers, turn signals and brake lights all went out at the same time. I talked to an electrician and he said to spray some WD-40 on your emergency flasher button, and work it up and down a few times. It has been known for it to stick. I did that, and sure enough it solved the problem, and hasn't happened since. (I have a 96 Crown Vic)
Saved me $700 what the Ford garage wanted to replace the fuse block power panel.
