Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 10-28-2005, 06:49 PM
Matt1100 Matt1100 is offline
Hi everyone..first time posting, problem w/ jetta
Im currently troubleshooting a problem on a 01' jetta vr6. Whenever its started up cold, mornings mostly, the car hestitates and stumbles as you give it gas. along with it is a bad rumble sound that comes from the exhaust that stops after 5 minutes. After about 10 mins of driving, its fine. one time it kept doing it for a good 20 minutes. Also, wheverever it feels like it, the car wont shift into 3rd gear, it wont even rev as well, no matter how much gas i give, nothing happens, jsut stays in second gear at about 25/30 mph and it wont move above that- this happens rarely though, whether the car is cold or not. did all typical checks- fluid, etc.. connected the to obc and cleared the check lite that pops up once in a while, made no differnce. the check light is always on though when the car is cold. ..any ideas? any info is appreciated. Thanks, Matt
Old 10-29-2005, 07:53 PM
boschmann boschmann is offline
Re: Hi everyone..first time posting, problem w/ jetta
What code is coming up?
Old 10-29-2005, 09:27 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
have you replaced your fuel filter recently? how about the coil pack?
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 10-30-2005, 12:59 AM
Fuel filter was replaced a few months ago.
Can the coil pack cause the problem based on the symptoms?
the code is for the mass air flow sensor, but theres nothing wrong with it.
