| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
I have a big 16g turbo on my 98 gst and when I hit anywhere close to 15 pounds of boost it starts jumping on me like a misfire. Could this be the plugs or maybe the fuel pump? The plugs are gapped at .30
Re: turbo detonating
What plugs do you have in it?
I would HIGHLY recommend getting a set of NGK BPR7ES's....those are a cooler running plug and great for higher boosting... gap them at about .030 or so...I ended up having my final gap at .027 to get rid of that "bucking/jumping" feeling when getting over about 5psi of boost. I had to pull my plugs about 4 times to get the gap right but when it was set my car pulled hard for what a T-25 will allow ![]() If I remember correctly, if you hit fuel cut you will definately know you did!!! It is more than just a jumping feeling. I would have to say it is your plugs. This is off-topic but here is a great website that you can learn alot from... www.vfaq.com check it out sometime in case you haven't already... Good luck and I hope this helps. Welcome to AF.com bro!!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
