Old 10-28-2005, 04:40 PM
T.McKinnis T.McKinnis is offline
Problem with signal light
I have a 96 Plymouth Grand Voyager and my signal lights work sometimes and sometimes they will not. I don't think there is a fuse blown because my auto intruction guide says that if the fuse needs to be change then the signal light will blink continously. I don't know if it is a shortage but I hate to pay someone a lot of money for a simple solution to the problem. Do anyone have any suggestions?
Old 10-28-2005, 07:19 PM
KManiac's Avatar
KManiac KManiac is offline
I would suggest looking at your flasher. I don't know where it is located on these vehicles, but it should be somewhere under the dashboard.
Old 10-29-2005, 02:06 PM
Vats Vats is offline
Check the Flasher unit. i had a simila problem with my 1999. The unit is located under the dash, just above the emergency brake. it's quite a complex unit as each flasher seems to run from its own circuit from within the unit. But i think that may be the problem.
