Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 10-28-2005, 04:12 PM
microvault microvault is offline
Send a message via AIM to microvault Send a message via MSN to microvault
I want More Power!!!
I just bought a 1993 dakota with a 3.9l v6. am looking for easy ways to get more acceleration from this machine. The cat is still on the exaust sys. also i have noticed that the air intake is right behind the grill but it looks like it is covered so there isnt any forced air going into it. what would happen if i opened that hole wide up???
Old 10-29-2005, 03:15 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: I want More Power!!!
It is a six cylinder.
My Mopars
Old 10-30-2005, 12:37 AM
look at it this way man. if there is a way for those idiots to boost up a 4 banger box on wheels, i am sure that there is something that can be done.
Old 10-30-2005, 09:14 PM
MyPsycho5Oh MyPsycho5Oh is offline
is the 93 fuel injected or is it still carborated???
Old 11-01-2005, 02:34 PM
this is a 93 3.9l v6 fuel injected engine with an auto tranny.
Old 11-03-2005, 02:39 PM
soapsuds22's Avatar
soapsuds22 soapsuds22 is offline
They make plenty of parts for your truck. Go here
http://www.truckperformance.com/vehi...TA&mode=change
Old 11-07-2005, 09:03 AM
fasstdak's Avatar
fasstdak fasstdak is offline
Send a message via Yahoo to fasstdak
There is plenty out there to increase the HP/TQ of the Magnum V6. You also have the option for a Mopar Performance PCM as they were built for the 93/94 models (V6). You also have the better exhaust manifolds on your V6 so there's a plus to the vehicle already. Throttle Body (simple V8 TB swap), relocating the IAT sensor, modifying the TPS (.70-75v), and just simple tuning tricks can gain you a noticeable difference.
You can check out my list of modifications as i'm running a 250HP 3.9L V6 in my '97 (that's also without the nitrous).
Email me if you need specific details - there's about 20HP available with minor modifications that are almost free.
Chrysler/Dodge Certified Technician
1997 Dodge Dakota SLT - V6/5spd CC
Carillo Rods, KeithBlack Pistons (10.75:1), Ported & CC'd Heads, Crane Rockers (1.7:1), CompCams custom camshaft, Mopar Drive Gear, Smith Brothers Pushrods (7.050"), Ported Factory Intake, APS 50mm TB, APEXi SAFC-II Controller, JBA Headers, Magnaflow "TurboXL" Muffler, Cloyes True-Roller/Dbl-Row Chain with tensioner, etc. Dyno Proven: 214RWHP/238RWTQ (Without the Nitrous)
http://www.dodgetrucks.org/fasstdak
Old 11-09-2005, 03:01 AM
Talking
Thanks Lot guys, i will check out all of what you have said and keep you posted.
Old 11-28-2005, 12:45 AM
well i have done nothing yet as i dont have cash yet but i did take the cat right out along with the muffler and stuck a resignator in there, theres a rumble now but still not much for acceleration
so i can get a mopar preformance pcm for my engine ehhh. would it matter if it is 4x4 or just affects the engine
Old 11-28-2005, 11:44 AM
fasstdak's Avatar
It doesn't matter on the older models as the SBEC system really didn't care whether it was 2WD, 4WD, Auto, and Manual. However, you "may" get some detonation (pinging) with the Mopar PCM unless you run Super Unleaded.
You can adjust the TPS to .75v (Free), relocate the IAT sensor into the Intake stream (Free), get the airhat and tube from a '97+ model 3.5/5.2/5.9L Dakota (or Durango) ($50 at a junk yard) and install a K&N filter on the end of it ($50 Autozone). That's good for a few more ponies and the performance will be a bit better than factory. Whatever you do, stay away from the chrome/round airfilters - they soak up heat and will cause a degradation in performance once the engine is up to operating temp (underhood temperatures).
Old 11-28-2005, 12:22 PM
neon_rt's Avatar
neon_rt neon_rt is offline
If you have the 3.55 gear set, you can change them out for gears in the 3.90 - 4.56 range.
Old 11-28-2005, 12:49 PM
fasstdak's Avatar
Re: Re: I want More Power!!!
Originally Posted by neon_rt
If you have the 3:55 gear set, you can change them out for gears in the 3.90 - 4.56 range.
Yup, gearing will also help, but at a cost of $200 for the Ring/Pinion and (if you're not able to do it yourself with the proper tools) - about $500 for the installation. If you're running with 31-33" tires, 3.90-4.10 gears are just about perfect. Anything larger (35"+) - you'll need to run with 4.56's.
