Old 10-28-2005, 01:36 PM
jeffreypca jeffreypca is offline
Question Don't start...
I have a 01' Grand Am. It fires but quickly stalls, just like no gas, so i figure security BUT I have no power to nothing else on there car, the only power I can see is the instrament panel, checked all fuses. I am clueless.....................Does anybody have any info at all, it would grately appriciated, Thank you!
Old 10-28-2005, 02:34 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Don't start...
Welcome to the forum. Have you changed your fuel filter? Checked plugs, wires, coil packs, TPS, ect?
Old 10-28-2005, 04:30 PM
Re: Re: Don't start...
Yes, I checked all that. No power to anything other than motor and ignition....
Old 10-28-2005, 06:34 PM
Gir-_-'s Avatar
Gir-_- Gir-_- is offline
Send a message via AIM to Gir-_-
Re: Don't start...
Have you tried to gas it slightly when you try to ignition? Also, think it could be the IAC motor on the throttle body? Ridenour or Xeno 'should' be able to help you out...
04' Mazdaspeed Miata - GT2860 @ 10psi
99' GRAND AM SE V6H.O. 188whp - Sold
Old 10-28-2005, 09:20 PM
Re: Don't start...
yes, tried gas slightly and just dies....
Old 10-28-2005, 10:41 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Don't start...
Could be a bad oil pressure sending unit. It has a fuel pump kill feature built in that shuts off fuel when no oil pressure is sensed. It is bypassed during cranking, so the car will crank over, start, then stall.
Old 10-29-2005, 09:07 AM
townie15 townie15 is offline
Send a message via AIM to townie15
Re: Don't start...
Hey I had that same problem with my 01 Grand Am and it was a securtiy issue. Someone on here told me to turn your key to the on position and let it sit for 10-15 minutes. Then go and turn the key off, let it sit for a minute, then try starting it up. It worked on my car, try it on yours.
Old 10-29-2005, 12:23 PM
Re: Don't start...
Well, I did try to reset it. I turned the key on "on" for 20 minutes to make sure it was long enough, the security light was still on. Then shut it off for 2 minutes.
Question though?? Is the security light suppose to be flashing when the security is tripped, cause my gf car is the same and it on too when I have the key on "on".....
Old 10-29-2005, 12:24 PM
Re: Don't start...
Where is the oil pressure sending unit located richtazz?
