Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 10-28-2005, 12:52 PM
Zyphyer's Avatar
Zyphyer Zyphyer is offline
Send a message via Yahoo to Zyphyer
Whats in a engine?
I have a 94 Honda Del sol S I bought used. It's been through a few peoples hands and i want to know how i can find out what engine is really in it.
I know the Car origionally came with a 1.5 ( i think) but someone dropped a 1.6 Vtec into the car. And to make matters more interesting, it's still an automatic.
Is there somewhere i can find an engine number to tell me what car this engine was pulled from? Were Civic Vtecs from earliers models the same as what was put in the Sol?
Any info would be helpful.
Old 10-28-2005, 01:15 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: Whats in a engine?
what makes you think someone dropped in a 1.6? They may have just done a head swap, which is VERY common... basically, there's a small flat square on your block right near one of the tranny mounts... kind of behind the edge of the radiator. Hard to explain, but look for it. It's on the front of the block, to the left. That space has an engine block code stamped on it. If it says D15B7 (which I'm willing to bet it does), someone did what's called a mini-me swap on the car. Bolted on a SOHC VTEC head to give a little extra power. If the motor says D16Z6 on it, they dropped in a whole new motor. If it is indeed a whole new motor, it either came out of a del Sol Si model or a Civic Si model from 92-95.. both came with the z6. It's still an automatic because doing an auto to manual conversion is a PAIN. If you're in a city that does any kind of emissions testing, then your motor is definitely newer than the car, because putting in a motor from an older car automatically flunks you on emissions. My theory in life at this point... if it runs, don't question it. Just smile and drive.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 10-28-2005, 08:12 PM
Zyphyer's Avatar
took forever to find anything!
following the radiator hose to the engine directly to the right is a stamp in the metal taht says B2071 and like 4 more charachters i cant make out.
is this the right number to look fior?
Old 10-28-2005, 09:00 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
The plate is right where the engine meets the transmission, like here: http://img.photobucket.com/albums/v4...poon/plate.jpg That one is from an H22a (jdm, so it doesn't have any numbers after the "a").
Old 10-28-2005, 11:23 PM
94SolGrl's Avatar
Thanks for the pic, spoon man.
You may have to wide some sludge off your motor to see it. Here's a link showing you a better idea of what you're looking for... and just so you know, it's the circled area on the block... don't go looking on the a/c hoses for a motor code.
http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg
~*Emily*~
HOW TO POST PICS!
Old 10-29-2005, 12:40 PM
Zyphyer's Avatar
never on the hoses! i found that number directly above the circle to the left of the arrow on the engine to the right of the hose.
It went in the shop this morning so when ik get it back i'll take a closer look.
thanks for all the help so far!
Old 10-30-2005, 01:13 AM
94SolGrl's Avatar
just as an idea, when you get it back, run by a parts store and pick up some degreaser, then go to a carwash and spray the degreaser on, then hit it with a good bit of water pressure. Gets built up goo off.
~*Emily*~
HOW TO POST PICS!
Old 10-30-2005, 05:36 PM
Zyphyer's Avatar
give solgrl a prize. looks like you were 100% right.
it is the stock 1.5 undernewath. major bummer.
Is this engine worth working on to make it fast?
once i pay off my other car cash wont really be an option, but i dont want to sink money into a car that will disappoint.
Old 10-30-2005, 08:11 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
If you have the money to get another motor than you can get a B series...other than that you can go turbo with the motor you have now...both ways will get you good power...if your looking for the cheapest route then turbo the sohc...they are a lot more limited in potential than dohc are...
Old 10-30-2005, 08:34 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
i would not boost a d15... thier rods are VERY small... prolly wont take more than 5lbs of boost... a d16z6 can handle around 8 lbs of boost.... if its already wired for vtec, it wouldnt be hard at all to swap in a d16 bottom end if you already have the head, if not its even easier to do itall at once, it took me and a buddie 5 hours to completely take his motor out, and swap a new one ... you can pick up a d16z6 motor from your local import yard/junk yard for around $500.... use the tranny you already have and itl be a nice little motor to boost.
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 10-30-2005, 08:49 PM
94SolGrl's Avatar
and the nice thing about D series (SOHC) honda motors is that there's plenty of them, and they can usually be had for under $500. Which means if you go boost happy one weekend and blow a hole in your motor, it's not a huge huge deal. Whereas if you blow a hole in a B series, it's usually upwards of $1500 to get a new motor.
~*Emily*~
HOW TO POST PICS!
Old 10-30-2005, 09:34 PM
Zyphyer's Avatar
i Appreciate the help finding out what exactly i have. Either way right now it's damn quick to scoot back and forth to work (not to mention a lot nicer on gas costs right now) I have some work to do body first. It took a glancing vlow from a semi and that needs fixed. If and when i work on my sol i'll prob have lots of questions, but for now i'll prob dump any extra cash i have into my truck. too bad the titan section has almost nothing in it...
Old 10-30-2005, 10:19 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Re: Whats in a engine?
yes, but, if your lucky like me, you'll only blow out the short block [knocks on wood] and have a salvagable head.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-31-2005, 02:20 PM
Zyphyer's Avatar
After lots of deliberation between the spouse and me, it was unfortunately decided that the car isn't worth investing in. between 2000 in body repair needed, and a couple other quibbles, the lack of a true vtec just sealed it.
It's a shame. when we bought it it had a lot of body work done to it and was a great buy. then it was vandalized, and a run in with a semi (me and the car were both lucky to live)
The car will go the route of any good honda. it will be a dedicated work car for years to come while we save up for our next car (a high end sports car.)
so sad.
Old 11-01-2005, 12:22 AM
94SolGrl's Avatar
lol trade sols with you. Mine needs $300 in repairs and it's good to go.
~*Emily*~
HOW TO POST PICS!
