Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-28-2005, 10:37 AM
johngood johngood is offline
Knocking
HELP - I have an annoying knock in what sounds like the valve/lifters that I can't get rid of. This is a 1996 V-6 3.2L Rodeo. I've tried Rislone but doesn't help. Motor has 135k on it. Any suggestions?
Old 10-28-2005, 10:59 AM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: Knocking
Earplugs.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 10-28-2005, 11:03 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Knocking
search for tick here. there is a ton of info on it.
also, it could be your timing belt tensor on the outs (should be changed everytime you do the timing belt).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 10-28-2005, 06:54 PM
Cat Fuzz Cat Fuzz is offline
The lifter tick in these engines is common and most people just put up with it. If I get some extra cash I might tear it down and see exactly what is wrong. My tick comes and goes and engine flush and various oils don't help. The only thing I do to minimize the noise is to change the oil every 3k miles. It always seems to make the most noise when its due for an oil change.
Old 10-31-2005, 04:37 PM
nykolos nykolos is offline
Does it knock at idle? is it a sharp knock? Have you run the engine low on oil? Worst case, it could be a spun rod bearing, could also be one of your pistons slamming up against the head, if this is the case, you need a engine rebuild or a new engine.
Old 10-31-2005, 04:47 PM
directory's Avatar
directory directory is offline
Re: Knocking
nothing like throwing someone into a panic.... hehe
most likely it's the "natural" sound of this engine, as many of us here have the sound. just keep the oil changed, you shouldn't have a problem
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 11-01-2005, 03:19 PM
KurtAZ KurtAZ is offline
Re: Re: Knocking
Nyklos must be a factory mechanic
