Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-28-2005, 11:15 AM
remmans remmans is offline
95 Aurora falls flat after 4000 RPM
I have a 95 Aurora when I floor the gas the car will not go above 4000 RPM and car will start slowing down. When I back the gas pedal to say half throttle the car shifts and runs failry decent. I have removed the Cat converter and Resignator because the cat had gotten pluged (143,000 miles). I have replaced the Plugs, Coil packs, FPR, MAP sensor, Fuel Filter. I cant find any vacum leaks with no error codes. Is there anything else that anybody can think of? O2 sensors? I have a spare motor so I can take some parts of one to use on the other
Old 10-28-2005, 11:59 AM
Indy8's Avatar
Indy8 Indy8 is offline
Re: 95 Aurora falls flat after 4000 RPM
Maybe this is Gods way of keeping you out of traffic school.
Quality isn't expensive, it's priceless.
Old 10-28-2005, 12:50 PM
Re: Re: 95 Aurora falls flat after 4000 RPM
First time we noticed this was running it down the quarter mile for the ET Finals at BIR. My son races it in trophy class and it has ran fine all year until the September race where this problem developed. Any ideas?
Old 10-28-2005, 03:23 PM
tjm's Avatar
tjm tjm is offline
fuel pump
'97 Majestic Teal Metalic, 233,000 miles of smiles
Member of the AURORA CLUB OF NORTH AMERICA
Old 10-28-2005, 04:33 PM
ghutchin ghutchin is offline
Yeah I was going to say fuel pump as well, at the higher RPMS your pump might not be able to deliver enough fuel. I would check fuel pressure first and try and check it at higher RPMs. Unfortunatly just sitting in the drive way with no load on the engine fuel consumption will still be minimal and a drop in fuel pressure might not be noticeable. I would run the car with a scanner on it too. I also doubt it is the O2's
Old 10-28-2005, 04:36 PM
Also how closely did you check the mufflers after removing the cats. If the cat broke up some of that stuff could be in the mufflers. In all honesty this sounds like an exhaust back pressure or a low fuel issue.
Old 10-29-2005, 03:30 AM
Indy8's Avatar
How long since fuel filter change? Pressure gauge kits are cheap and a good place to start. Check high and low side of FPR. If you have good pressure, you usually will not have a low volume(flow) problem.
Old 12-05-2005, 03:42 PM
Fixed! Aurora falls flat after 4000 RPM
The mufflers were packed with Cat convertor packing. Installed new mufflers and after putting on about 4 miles power came back. Do not know why it did not run correctly as soon as I put the new mufflers on. So I have removed the cat and resignator on the exhaust. Does anybody see a problem with any sensors by doing this?
Old 12-05-2005, 03:45 PM
Should be no problem running without the cats and resonators on the 95 sensor wise. Other than sensors the cat usually provides some backpressure which is deserable if the engine has been designed around it, but I wouldn't worry about it. The reason it probably took some driving to get everything straightened out is that the computer probably had to undo some of its settings that had been made when the car was running like crap. Good to hear you figured it out.
