Old 10-28-2005, 06:25 AM
angelmarr7 angelmarr7 is offline
Angry Thor car alarm system
I just put in a THOR system in my truck, but when i remote start my car, the alarm activates, and won't allow my car to start. What's wrong?
Everything else works fine, but this, please help.
Old 12-29-2006, 10:04 AM
travis_lowe1983 travis_lowe1983 is offline
Re: Thor car alarm system
Hello I just bought a thor alarm and I cannot get it wired right is there anyway you can help me? Thank you!
Old 12-29-2006, 02:05 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
when you install an auto-start kit, I think you have to have ALL of the sensors installed AND wired up correctly. You probably missed one.
Old 01-01-2007, 07:33 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Well, first I'll tell you that I've installed a few of those Thor systems and I wouldn't use them as a paperweight!
That aside, what kind of car do you have and what information did you use to get it installed?
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 01-05-2007, 10:58 AM
Steenad Steenad is offline
Hi, I have also installed a Thor system, everything works besides the tach signal, where should I connect it? The manual says to +12V when the car is running...A tach signal is ACV or not?
Best regards Steen, Sweden.
Old 01-06-2007, 12:22 AM
Audio Guy
why would an alarm have a tach ?
Old 01-06-2007, 12:35 PM
Success of starting when using the remote starter. Maybe wrong term "tach", I donīt know.
Old 01-06-2007, 08:16 PM
because alarm/remote start combo alarms need to either see a tach or voltage sensing.
Not sure what that wire should go to. On the ones I sell/install we usually connect it to either a coil or injector wire.
Pioneer 4900mp
Orion C63 Coax rear
Old 01-07-2007, 02:28 PM
Audio Guy
ok, to make sure the car is running ..... duhh
Old 02-12-2008, 01:13 PM
Warrenwiz5 Warrenwiz5 is offline
I am in the middle of putting in a THOR system, and I have the locks working, but unfortunately I dont know enough about cars to know where to look for my ignition coil to tie into the remote start function.
I have a 98 Ford Taurus.
I basically know nothing about cars; I mean I know a little, but probably nothing like you guys do... so I thought I would see where I should start looking. I see this 6-plug connector on the side of my engine that I thought was my coil, but the wire it told me to look for (Yellow w White strip) I couldnt find anywhere.
I thought I would ask you guys before I cut open all of my wires under my hood to tie into the motor sense switch.
-Warrenwiz5
Old 02-13-2008, 03:45 AM
murd3rd's Avatar
murd3rd murd3rd is offline
1998 Ford Taurus Alarm, Remote Starter, Keyless Entry Wiring InformationConstant 12V+Yellow or Light Green/Purple Ignition Switch Harness StarterRed/Light Blue Ignition Switch Harness IgnitionRed/Light Green Ignition Switch Harness Ignition 2Gray/Yellow Ignition Switch Harness (Blower Motor) Ignition 3Red/Black Ignition Switch Harness (AC) AccessoryRed/Black Ignition Switch Harness (Heat AC) TachYellow/Black Multi Coil (Tan/Yellow Passenger's Firewall PCM 48) Neutral Safety WireNot Grounding OEM Switch opens Starter Circuit Brake SwitchRed/Light Green Brake Switch Trunk ReleaseGray/Red (+) in left Kick Panel (+) Trigger Trunk PinBlack/Pink (-) Trunk Light (Wagon White/Purple right Cargo) Parking LightsBrown (+) Light Switch Head LampRed/Black (+) Harness left of Ignition Switch Harness Factory DisarmPink/White (-) Driver's Kick Panel (Pink/Blue to Arm) Door TriggerBlack/Light Blue Black/Blue in left Kick Panel. Door LockPink/Yellow (-) Driver's Kick Panel Door UnlockPink/Green (-) Horn WirePurple/Orange (-) Steering Column 4 Pin Connector Windows UpLF=White/Black, RF=White/Yellow, LR=Yellow/Blue, RR=Yellow/Black Windows DownLF=Orange/White, RF=Tan/Blue, LR=Gray/Orange, RR=Red/Black
Old 02-14-2008, 01:26 PM
Thank you for the wiring list, it is appreciated.
The problem I'm having now is where to look under the hood. I dont know if I should be looking around the engine, behind the battery, etc.
Keep in mind that I know next to nothing about cars, so that just makes the situation even better.
I believe I'm looking for a yellow with (white or gray) stripe on it, but the once I've spliced into arent sensing any voltage change when I hit the button on my remote. (AKA, it wouldnt start if I hooked it up to that wire.)
Any suggestions on where to look under the hood? Technical terms are good, too as I have a car book that lines out each subsystem (which I thought would have helped me find that wire, but unfortunately didn't, as it doesnt list color of wire with each subsystem.)
Old 04-19-2008, 09:27 AM
Now that classes are over with, I'm going to start working on my car again, and I'm wondering if you guys have any way of helping me over the internet.
I have a digital camera, so I can take pictures of what I'm working on and what's going on... because the problem I'm running into right now was that the thing that I thought was the motor sense switch wasnt sending a signal when I started the car (AKA not sensing that the motor is on). So, if any of you guys know what I might look for, or what I can do... that'd be great. Thanks guys!
-Warrenwiz5
Old 04-19-2008, 02:48 PM
Audio Guy
I have never done a remote start and ponchonutty doesn't come around much anymore. I would think that "tach" signal is the same wire you would tap into for a tachometer. I would say to look around the distributor.
Old 04-19-2008, 08:11 PM
Once the tach is hooked up, you have to make the remote starter "learn" the signal. You don't have to use the actual tach either. A signal from an injector will work too. Just find the wire color that's not common with the other injectors.
Pioneer 4900mp
Orion C63 Coax rear
