Old 10-28-2005, 12:25 AM
nalgman's Avatar
nalgman nalgman is offline
Post 4.3 spark plugs..25 & 26
mm, ok..
my babe is an 4.3L 2wd blablabla..1990
so i tried to know what was the reaction of my truck with different spark plugs..
i usually use the autolite #25 platinum.. and run like a puppy!
but with the new spark plugs.. autolite #26.. the sound is different..
with this runs rough.. very rough...and smells more gas..
tomorrow i'll change this horrible things..
who had the same problem??
this is just to let you guys know..
Nalgman
Old 10-28-2005, 02:27 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: 4.3 spark plugs..25 & 26
I debated between these two heat ranges for my engine . Did alot of research . The 4.3 uses these two in many of the autos and van . You may have the hotter plug in when you dont need it and you are are getting preignition/detonation . And the knock sensor is retarding the ignition to counteract it causing incomplete burning of fuel , that you smell. I would go back to the original number , I did. Rob
Old 10-28-2005, 08:57 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Re: 4.3 spark plugs..25 & 26
Yep.....it sounds like your engine is retarded.
Old 10-28-2005, 02:22 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Re: Re: 4.3 spark plugs..25 & 26
Only to a degree
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 10-28-2005, 02:28 PM
blazee's Avatar
Problem?
Re: Re: Re: Re: 4.3 spark plugs..25 & 26
Originally Posted by Gabe25
Only to a degree
ROTFLMMFAO
Old 10-28-2005, 08:43 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Go Oem AC-delco spark plugs and use what plug no and gap the book calls for on it and your problems will be over with.
OEM parts only hurts one time. The other stuff may hurt many times.
Auto lite does not always get the heat range match to your truck and engine that it needs. It is a sometimes they do and sometimes they do not deal.
MT-2500
