Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-27-2005, 11:15 PM
regalfriend regalfriend is offline
Hub replacement...New axle too?
Im pretty sure my hub is bad... when i put the car on a lift i was able to wiggle the tire. It almost seemed like the tie rod was bad. Tie rod was not moving and had been replaced 2 months ago. When i make a right turn there is a vibration that seems to come from the left wheel. When i make a left turn there is no vibration. Car has new struts , tires alignement. The parts guy i use has always been honest with me..I asked.."If i have gone as far to remove the hub should i replace the axle too"? He told me...as much as he would like to sell me the part, unless the boot is cracked and there is no clicking from the axle i shouldnt replace it...He also told me GM corrected the problem that the early 90 cars had with the axles and that later model GM cars have much better axles.... I do believe him...my question is...how many miles can you get out of an axle on average?
Old 10-27-2005, 11:42 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Hub replacement...New axle too?
How many miles do you have on your Regal GS? Checkout this link, it may help answer your question:
http://www.counterman.com/cm/cm110420.htm
Timeslip 08/12/06
AF Community Guidelines
Old 10-28-2005, 05:57 AM
GTP Dad GTP Dad is offline
Pontiac Guy
The link Bob provided is great information. I have seen CV joints and shafts last well over 250K miles just depends on the circumstances. I had a Chrysler van with 162K when traded and the front shafts were solid as a rock. If you have a bad bearing or hub replace it. Don't waste the extra money on a new shaft if you don't need to.
By the way, hold on to that mechanic! Sounds like you found an honest one.
