Old 10-27-2005, 10:23 PM
jadeacuna jadeacuna is offline
Question Cavalier Z24
I Own A Chevy Cavalier 1996 Z24. It Stars, However When In Gear, It Dies!!!! Reverse Is Ok, Nothing Happens, It Dies Just When Shift To Any Other Gear (automatic Transmition)
Please Send Me Any Ideas Or Opinions , Thanks A Bunch!!!
Old 10-29-2005, 11:19 PM
vamc's Avatar
vamc vamc is offline
Re: Cavalier Z24
Have you done a tune-up in it lateley? that could be the problem.
Old 10-30-2005, 07:27 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Re: Cavalier Z24
Could be the cat.
Old 10-31-2005, 09:05 AM
graymarki graymarki is offline
TCC Solenoid!
I'm not that familar with a 96, but on the earlier models with auto transmission, they have a tcc solenoid in the tranny that allows the car to shift into overdrive. When this solenoid becomes defective, the car will start but stall in gear. My 89 Z24 does this occassionally, but not always. You can jack the car up and disconnect the wires going to this solenoid and see if it still dies. If the car runs ok, then you need to replace the tcc. If this does work, don't leave the solenoid disconnected, as your gas mileage will turn to crap. If this doesn't do the trick, then I would check for a bad neutral safety switch. The solenoid cost is about $40 at your local parts store. There is a post on this from another site and I will see if I can locate for you.
graymarki
Old 10-31-2005, 12:20 PM
vamc's Avatar
Re: Re: Re: Cavalier Z24
Originally Posted by 97cavalier
Could be the cat.
anything is possable.
