Old 10-27-2005, 07:36 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
97 lumina 3.1 #3 missfire bad plz help
my 97 lumina has a bad missfire, cyl 3. code was p0303, so i changed all the spark plugs they were all white except #3 was black and oily. i also change the coil pack and the spark plug wire to #3. still no luck. some suggestions i stumbled across were the egr valve, oxy sens, low fuel pressure, bad injectoror valve or compression problems. i was wondering if anybody knew which of those would be more likely the cause or if some one else has had this problem had a suggestion. any help would be great, and by the way this happened once last year but quit and it restarted about 4 days ago.
Old 10-27-2005, 08:07 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 97 lumina 3.1 #3 missfire bad plz help
If it's oil, it shouldn't come and go. Did you smell it, and make sure it wasn't wet with fuel over a sooty plug?
Does it blow a blast of smoke when you start it in the morning?
Put a good plug in the #3 wire, ground it on the motor and start it for a second to verify that it is actually firing.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 10-27-2005, 08:22 PM
Goober
no smells of burning oil no smoke either, but i never thought about seeing if it had the spark ill try that out. also the plug wasnt smelling like fuel or oil really it was just black, not charred but not real fresh or wet looking either
Old 10-27-2005, 08:36 PM
Goober
and also i have replaced all the plugs and threw the old ones away so i cant go back and look at it.
Old 10-28-2005, 12:54 PM
Goober
any other suggestions
Old 10-28-2005, 06:59 PM
maxwedge maxwedge is offline
A990 racer
Get a stethoscope on the injector body #3 see if it is clicking, if not it is bad, but it still could be the problem if if there is a clicking, a good scanner can do an injector balance test also.
Old 10-28-2005, 09:42 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Since it's just one cylinder, you can rule out all but things specific to that cylinder. All the other things you mentioned would cause problems across all cylinders, not just one. I would do a compression test to see if #3 is lower that the rest. If compression is good, I would lean toward a bad injector, as you said you replaced the plugs and wires. The #3 and #5 wires are close to the same length, so you could swap the two around (on both the coil and the plugs) to see if the problem moves. If it doesn't, and compression is ok, then you need an injector on #3.
Old 10-29-2005, 01:16 AM
Goober
thanx ill try swapping them
Old 11-03-2005, 08:49 AM
wafrederick wafrederick is offline
Banned
Replace the #3 fuel injector.The 3.1 has fuel injector problems once in a while.
Old 11-06-2005, 01:11 PM
snovak0904 snovak0904 is offline
97 lumina misfire
I have a similar problem with misfire but is on cylinder 2. It only seems too occur when we go from summer to winter fuel mixture. I did change all wires and plugs. can anyone help would the coil pack or fuel injector be the problem. And is it easy to change fuel injector. Email me at [email protected]
Old 08-24-2009, 08:28 PM
Goober
Re: 97 lumina misfire
Trying to button up some old posts. Turns out after i changed the injector, the fuel line o ring was bad, stores had the wrong one in stock ( all stores, didnt fit the line into the injector body. Car ran ok but not right still. went back and turns out one or 2 of those spark plugs, the brand new ones, were defective. /sigh changed those and it ran till may of this year and the head cracked, (was my sisters car.)
Old 08-27-2009, 03:34 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
bad injector if its a dead miss
common issue
also on the 3800 engines
just had ot replace injectors 5 and 6 on a 99 lumina 9c6 car about 15 minutes ago due to failure of them,
[now it runs super strong smooth lots of power perfect
driving it right now
try unplugging injector while running
if no change then thats the problem
easy check
swap an injector from another engine etc
dont use a #6 or #5 injector though
because those are the ones that plug up the most common
and are the oens we have ot change always
all the others never have issues
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
