Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-27-2005, 06:54 PM
biggamer biggamer is offline
noisy rearend
I believe the rearend of my 99 dodge ram is going out. It makes clunking noises when starting off. Its worse if I'm stopped at a light and then accelerate into a left hand turn. Noise stops after about 100 feet.
Any idea's as to which gears may be going bad or could it be a rear universal joint?
Old 10-27-2005, 08:54 PM
Kentw Kentw is offline
Re: noisy rearend
Hopefully it's a u-joint as that is much cheaper. It's easy to check. Just crawl under and grab the driveshaft at the end right before the u-joint. Try to move it up and down and side to side. If it moves, it is bad. Also try to rotate it while holding the yoke. If it rotates and the yoke doesn't, it is bad. Check the other end too. The grease in the ujoint eventually disappears causing the metal needle bearings to wear.
Old 10-28-2005, 09:53 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: noisy rearend
If that's not it, check your lug nuts. If one is loose it could make the noises your hearing.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 11-01-2005, 09:11 AM
statler statler is offline
Re: noisy rearend
Does either wheel cover feel hot after driving it for awhile?
Oh, and one sure fix for a noisy rearend... Quit eating beans.
