Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 10-27-2005, 06:43 PM
charlesdddd charlesdddd is offline
tsunami amps
hello all im new here and i have a problem and wish you guys can help me i got an amp from my brother and it blew on me it was a great amp but now i cant find another 1 like it anywhere it is a tsunami generator x gxa10000 if you can find it please let me know where at again thanks a million this is driving me crazy
Old 10-27-2005, 07:58 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: tsunami amps
if it blew the first time you had one why would you want to buy another?
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-28-2005, 08:08 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: tsunami amps
why not buy a kicker, mtx, punch, or another brand name amp?
Old 10-29-2005, 03:23 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
out of curiosity...what exactly were you doing when it blew. Are you sure that it is "blown", or is it just a fuse. Most powerful amps have multiple fuses, and if even one blows the whole amp shuts off. Also, if you knew what you were doing you would have a fuse block from your battery to your amp...check those fuses. Tsunami isnt known for amps...they are more capacitors and other assisting devices, so my guess is that even though it may have had lots of power, it was a piece of shit because of who made it. I will say what Eclipsed said...why not a better, probably more powerful one. (kicker has a 2500 watt mono amp...if that isnt enough power i dont think you are alive)
Old 11-01-2005, 08:36 PM
ok i thank you for your replies but if you read what i asked none of you helped did you? i asked if you knew where to get the amp not how you felt about the amp did i this is what i want for my system i like it and thats it now again does anyone know where i could get a TSUNAMI GXA 10000 GENERATOR X AMP ON LINE AGAIN THANKS IN ADVANCED
Old 11-01-2005, 11:35 PM
cficare68's Avatar
cficare68 cficare68 is offline
Re: tsunami amps
sorry dude. Tried to search the net for you with no luck. Good luck finding the answer for your question, as far as fuzes go on an amp my amp is wierd it is 2500 rms and 3500 peak and it has no fuzes on it.
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 11-02-2005, 07:34 AM
Re: tsunami amps
well i did a quick google search but i couldn't find anything. you could probably try ebay.
but you didn't answer rodbls' question. how do you know its blown? have you checked the fuses(if you have any)?
Old 11-02-2005, 03:19 PM
rodbls's Avatar
I did a google/ebay search, and couldnt find any Tsunami amp period. I looked at Tsunami's homepage, and they dont have any amps on there. Do you know how old this amp was? I have a tsunami 2 fahrad capacitor, and it's a piece of shit. Does anyone know if anyone makes upgraded alternators for our car? I know that i can get an upgraded alternator, but dont know if it will bolt on to factory location (i am looking for like a huge 250-300 amperage uprgade)
Note for anyone with power issues due to powerful stero applications:
The most effective way to improve your audio performance is to increase the power to your amps. This can be done most effectively by upgrading your alternator (stock ours only put out like 80 or so amps). I crunched some numbers, and for my stereo application (about 2500 watts rms for mids and woofer) I need around 250 amp from an alternator. Not only does under amperage cause your lights to dim, and possible cause amplifier clipping, it also can cause premature alternator failure. A capacitor can help, but only so much.
Another way to help is with a batter isolator. Note: Adding another battery without an isolator will do very little to help with under amperage because you are not increasing your alternator output. Make sure that if you add an isolator and additional battery that you get a sealed battery if you put it in your passenger compartment.
If anyone has any aftermarket stereo questions let me know, ive become pretty good at figuring out ways to make things work.
Old 11-02-2005, 06:44 PM
thanks anyways for trying yes i did check fuses thats not it i took it to the shop they are trying to fix it when its hooked up it pushes the subs out they said that some how the amp is putting pure power to the subs and it could be just a loose wire again thanks for the effort
Old 11-03-2005, 09:25 PM
cficare68's Avatar
Re: tsunami amps
Yeah could have just fryed a resistor. Fryed 3 in my amps about 3 months ago. Still waiting for cadence to fix it but oh well at least it is fixable.
Old 09-26-2010, 08:23 AM
SANCOENT SANCOENT is offline
Talking Re: tsunami amps
I have one available if you're still looking
Old 09-26-2010, 08:28 PM
808drifter 808drifter is offline
Re: tsunami amps
yeah he wants one 4 years later.
ass....
