Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 10-27-2005, 04:24 PM
darkerdayz darkerdayz is offline
Send a message via AIM to darkerdayz Send a message via MSN to darkerdayz Send a message via Yahoo to darkerdayz
Lightbulb turbo sizing
whats good all my Honda-heads.
i'm tryin to do a custom turbo for my car and was hoping i could get some advice from some current turbo owners or people that know a decent amount about turbos.
i have a 2.5 L block and was wondering what size turbo i should go. i know that most likely i'll be using a t3/t4 hybird (possibly t3/t04e), but i'm not sure what other numbers i should look at [i.e. actual specs like the a/r numbers for the turbine and compressor]. i'm pretty much looking for a turbo that'll start spooling by about 2-2.5k RPM and will not run out of breathe at least untill around 6.5-7k RPM.
i'm only looking to run about 8, maybe 10 psi MAX on this block and when i get the japanese motor, i'll be looking to build it to run a MAX of 25 psi.
so pretty much, i dont want to have to buy 2 turbos. i want to find one that'll suite my needs for now and for later.
thanks for ur help
mSweezy
friends don't let friends drive stock
Old 10-27-2005, 05:51 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: turbo sizing
Look into ball bearing turbos. If you want to spool by 2.5k rpm you'll have to go with a tiny turbo unless you get a ball bearing one.
Empty Pockets Racing Member #1
Old 10-27-2005, 07:24 PM
97integrals's Avatar
97integrals 97integrals is offline
what are your horsepower goals? psi means nothing.
Old 10-27-2005, 07:36 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: turbo sizing
PSI doesn't have any sort of relevant meaning......
You should read up on the subject so that you'll have a better idea of what you're talking about.....
http://www.beesandgoats.com/boostfaq/g2icturbo.html
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-27-2005, 08:42 PM
Re: turbo sizing
my apologies.....
i'm looking to make about 250 wheel horsepower on this motor. i'm currently running about 170 to the crank, so i'm just looking to add a little oomph to my car.
thanks alot.
ps. i've been reading up on that link u gave me and it is very informative....
Old 10-27-2005, 09:50 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: turbo sizing
what did you do to your motor to make it a 2.5L ?
Team Lonely Drivers
Old 10-27-2005, 11:22 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: turbo sizing
2.5 L on what?
read the above link.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-04-2005, 11:00 PM
Re: turbo sizing
although i dont see how knowing what i have 2.5L is of any relevance to my question, if u feel that u must know, it came str8 from HONDA just like that......
Old 11-04-2005, 11:13 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: turbo sizing
It'd help if you said what engine you have (or even car) so people could look up some specs (especially compression ratio of the engine); to better help you. If you don't want to give out info, then you're just going to get a half assed answer for giving half assed info. That kind of info is relevant to your question, that's why it was asked.
Old 11-05-2005, 12:16 AM
AF - Advisor
Re: turbo sizing
turbo sizing on a 2.5 what? motor is? compression is?
you are correct................2.5L has no meaning. its meaning on different honda engines is limited. thats why the question is asked.
no one is busting your balls here. if you dont know or understand the importance of what base engine you are working with to begin with, besides just providing a "2.5L engine" as info, then, reread the above link. it will help you understand some info.
ex. im boosting 10lbs on a sc34 on a 2.0 b18c vs im boosting same thing on a 1.8 b18c. do you see what the difference is yet? if not, reread the link and do a search.
Old 11-09-2005, 05:24 PM
Re: turbo sizing
G25A......Acura Vigor
c/r 9.3:1
