Old 10-27-2005, 04:01 PM
Bboy_Jon Bboy_Jon is offline
My Subs are HERE!!!!!!!!!!!!! (help wiring?)
my subs finally came in over a week from when i ordered them
and so today im working, but tomorow im off and ill install it tomorow!
heres my amp (profile ap1200)
and now my subs (Pheonix gold R12D's)
so sexy...
ok got a question, on my box, how do i line up my template that came with the subs (for drilling holes) how do i center it over the hole that the sub goes in?
or should i just stick the sub in and mark the holes with a marker?
and i can just use drywall screws?
i currently have 5 gauge for power and either 8 or 9 gauge for ground, will it help if i use both the 8 and 9 gauge as my ground (stick both wires in the amp)??
Old 10-27-2005, 06:00 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: My Subs are HERE!!!!!!!!!!!!!
i just put subs in, turn them to the angle i want, predrill the holes, take the sub out, clean the dust off the sub, put it back in and use one of thoes guards and just screw it in...
Old 10-27-2005, 06:40 PM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
I like your comforter. But something smells a little fishy.
Old 10-27-2005, 10:16 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
Usually the power and ground wire should be the same gauge. I've never heard of having 2 grounds for 1 amp so I don't know if that would work. Remember to keep your grounds as short as possible.
'87 Chrysler NewYorker
2 12" Ascendant Audio Assasins in Sealed Box
Hifonics TXi 6406 Bridged to 2 Channels
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 10-27-2005, 10:42 PM
ya my 8 is 3 ft, i have 4 feet of 9
the subs came with paper with the holes marked out, but ya it seems it would probly be easier to just put the subs in and drill
my sheets are awsome
Old 10-27-2005, 11:14 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Use the same gauge all around
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 10-27-2005, 11:16 PM
well i cant i onl y have 14 ft of 5 gauge
and that will barely make it to my trunk (itll make it but i have no idea whether ill have to mount the amp on my sub box or if i can mount it seperatly)
so i only got 8 and 9 gauge
Old 10-28-2005, 01:15 AM
how do i wire them? there dvc, and do i have to solder? theres screws on the connections so i could just use ring terminals right?
and uhh how should i wire them?
from here
http://www.edesignaudio.com/wiring.php
under dual subwoofer systems do i use the first pic or the 2nd one?
its 200x2 at 4 and 300x2 at 2 ohms on my amp
the subs are 250rms so it would be better at 2 ohms right?
do i use the bridge connection or each sub for each channel?
for my leds, id wire them to the ground and the remote turn on right?
would i connect the positives and the negatives form each sub (the led + and -) in parallel? or should i do it seperate?
Old 10-28-2005, 12:31 PM
CBFryman's Avatar
Banned
if you are going to use different guage ground should be the larger
so go pick up some cheap 4ga from home depot...jesus it isnt that big a deal.
Old 10-28-2005, 12:48 PM
highteknology's Avatar
highteknology highteknology is offline
Send a message via AIM to highteknology Send a message via MSN to highteknology
what is the ohm rating for the subs?
Old 10-28-2005, 03:31 PM
ohm rating is i think 4
does homedepot have 4 gauge?
Old 10-28-2005, 07:18 PM
CBFryman's Avatar
Banned
yes, they have 4, 2 1/0 2/0 and 3/0, or at least all of the ones i have been in.
Old 10-29-2005, 02:23 AM
well i got my subs wired up in my box (took waaaaaaaay longer then i expected) and they work (only tested it with a hometheatre amp though)
tomorow i gotta bring my power cable and my base remote cable through to my trunk to see where the amp can mount, then i gotta mount that, and wire all them up
My dad happened to have 2 sony xplods (we think they are sony xplods, they have their own boxes, there around 6.5 inch or so) (ive known about those speakers but i didnt think they were any, uhh known brand)
and ya there not the best, bbut better than stock, how do i switch em out? just cut the wire onthe stock speakers? and connect to the new ones?
Old 10-29-2005, 11:28 PM
the stock speakers just have a little plug that you unplug and the sony's should plug in. i know that Honda cars have speaker harnesses taht you may need to pick up from auto zone or something like that.
Old 10-30-2005, 12:39 AM
ya i saw the plug
but theres one on the wires, and then one on the speakers, wont i need one for the speakers?
