Go Back   Automotive Forums Car Chat > Ford > Contour
Old 10-27-2005, 03:37 PM
dmc67 dmc67 is offline
Send a message via AIM to dmc67 Send a message via MSN to dmc67 Send a message via Yahoo to dmc67
95 Ford Contour 4cyl help please
ok here's what the problem is. One minute it will run fine and dandy next minute it will start to shut off and black smoke pours out the muffler and it acts like it's floodin out. the Check Engine Light is on but has always been on since the car was bought. Is their a way to read the CEL without taking it to a dealer? Someone said it was an O2 sensor but I dont really know. dont wanna spend anymore money on it than I have to. any help would be appreciated
Old 10-27-2005, 06:34 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
yes, take it to autozone and theyll pull the code for free. If they cant tell you the meaning, tell me your code and ill tell you what it means.
I highly doubt its your 02 sensor if its running extremely rich. Your 02 sensor has no control over that.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-27-2005, 08:13 PM
Re: 95 Ford Contour 4cyl help please
See I live bout 75 miles from Autozone and I dont wanna attempt to drive it their b/c when it shuts off it dont wanna start back and ya can be goin down the road and it will just shut off. Any ideas on what it could be?
Old 10-27-2005, 08:27 PM
Re: Re: 95 Ford Contour 4cyl help please
im sure its a code saying that your rich.
"The CEG Nazi"
www.contour.org
Old 10-27-2005, 09:27 PM
any idea what would be causing it to run rich and shut off?
Old 10-28-2005, 06:59 AM
could be numerous things. Your injector harness wiring could be cracked and your injectors could be arching causing them to run full duty. There was a recall on all the harnesses from 95-early 98, because the insullation on the wires cracked. Could just be a bad injector, but I highly doubt that. Could have something to do with your MAF. Get the codes pulled and that could give a good indication.
"The CEG Nazi"
www.contour.org
Old 10-28-2005, 07:35 AM
is their a way I can pull the codes myself?
Old 10-28-2005, 11:12 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
go to walmart and get a OBD-I scanner
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 10-30-2005, 08:24 PM
phil-l phil-l is offline
Actually, you don't need a scanner to read codes on the '95 Contour, which uses Ford's EEC-IV engine control system, sometimes referred to as OBD-I. Later ('96 and up) models use OBD-II, a far more complex interface standard, which requires a scanner.
Here's the best info I've found on this topic:
http://www.thorssell.net/hbook/index4.html
Note that the free pages are more than enough for what you need to get started.
Note that since the '95 Contour has a check engine light, you only really need a paper clip to dump the engine codes.
