Old 10-27-2005, 03:32 PM
Wick001 Wick001 is offline
How important is it to change your Automatic Trans Fluid?
What are some tell tale signs that you need a trans flush... My Blazer has 64k on it, its a 1995 4x4 ( just bought ) and i'm wondering if it needs to be changed, or when you should change it. i dont think it ever has been...
Old 10-27-2005, 03:51 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: How important is it to change your Automatic Trans Fluid?
You answered your own question. If you just bought it. You don't know if it has ever been changed and you got 64K on it. Just go ahead and change you fluid , filter and gasket set. It would be alot cheaper to do maintenance to the trans then it would be to having it repaired because the fluid has failed. I would also change your Motor Oil, Filter, Complete lubing of under carriage, Air Filter, Plugs, Cap & Rotor while your at it. This way you know exactly when a full maintenance was performed. Plus it should run better then it is now.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 10-27-2005, 04:03 PM
JA no Y's Avatar
JA no Y JA no Y is offline
If you check your fluid and it is not the clear red color (kinda like cough syrup) or your tranny starts to slip, its definately time for a change.
It's best to change the fluid and filter before you have any signs that it needs to be changed. Once the fluid starts to turn it can start to cause damage to the tranny. Should have a routine maintanence schedule for your vehicle. They don't list recommended intervals for maintanence in your owners manual for nothing.
Old 10-27-2005, 05:36 PM
jsgold jsgold is offline
My suggestion to get a full flush as well as dropping the pan and replacing the filter. Changing out the fluid in the pan only will only replace a portion of total fluid. Personally I try to change the pan and fluid (and filter) every 30K or so to keep the crud from building up in the pan and then a total flush and filter change every 60-75K. Of course, opinions will vary on this. Some do more, some do less. (A few do nothing which is wrong)Assume that the fluid has not been changed and go ahead with total flush as well as other things advised.
I used to be indecisive, now I am not so sure.
Old 10-27-2005, 07:51 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
mine has 200,000 + miles and i have no idea when it was changed. i bought it in may 05. i'm definately going to have this done. if i take it somewhere to have the trans fully flushed, do most shops replace the filter or does the flush clean the filter so it doesn't require replacement?
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-27-2005, 11:50 PM
The actual flushing would still leave the old filter in and any crud built up on the magnet and bottom of pan, so you would have to specify you want both a flush and filter change. Then they would have to drop the pan and clean it and the magnet when changing filter. Some people have voiced concerns over flushing a real high mileage transmission, especially if it has never been properly maintained. There are two arguements, one being that a transmission can get "dependant" on the old particles floating around as they would actually help old worn clutches keep from slipping, and two, that if done improperly that you can blow seals in an old transmission with too much pressure. Personally, I have done this either myself, or had it done on cars and trucks well over 150K miles with no problems. I did have an old Mustang back in the 70's start slipping after a simple fluid change but this poor old car had never been taken care of, and this only showed the need for repairs. Letting old crap float around only delays the inevitable and would cause further damage.
Old 10-28-2005, 07:49 AM
How much does this usually cost? to flush and new filter, will any oil change shop do it?
Old 10-28-2005, 07:58 AM
Here in WV normal cost on total cleaning would be around $125 or so.
Old 10-28-2005, 09:16 AM
ZL1power69's Avatar
GM S-Series Mod
do most shops change the pan gasket or do u have to take one with u.
Low 11 sec sleeper
My Cardomain
Old 10-28-2005, 09:44 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Most shops, at least that I've dealt with, like to have their own parts. This way they can hit you with 30% or more upcharge.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 10-28-2005, 09:53 AM
93LT 93LT is offline
Back in 2000 when I had taken our previous 94 Blazer in to one of those quick lube places for a tranny flush and filter change, it cost about 90 bucks. I thought that was actually a pretty good price considering what a pain in the rear it is on the first gen. body. That is the only time I let a shop replace the filter and gasket, since I do the filter and gasket my self, after getting about a 1000k on the filter change I will take it in for a flush only.
I think transimissions are the single most neglected piece of equipment on an automobile.
