Old 10-27-2005, 03:18 PM
pwogjr pwogjr is offline
Fuel Pump installation on a F150
I'm not a mechanical guy, but I need to know if there is anyone that can tell me the level of difficulty installing a fuel pump on a 2001 F150. The dealership wants to cahrge me $750 for the part, so I figured I could do it cheaper, I have the time right now. Any advise, are there books on this stuff?
Old 10-27-2005, 06:19 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Fuel Pump installation on a F150
You can either drain the tank, lower the tank and remove the tank---or---you can remove the filler neck from truck body, disconnect the wiring in the rear of bed, unbolt bed(have a couple of friends help) slide back far enough to access the tank. Then you don't have to drain tank or lie flat on your back to take tank down. Your choice. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-27-2005, 08:06 PM
unclebubbles unclebubbles is offline
Re: Re: Fuel Pump installation on a F150
I agree, sliding the bed back, is alot easier than rolling around on your back, if you dont have access to a lift. Heres another trick that works very well, that i use whenever possible. Cut a trapdoor in the bed over the pickup tube assbly. Use a jigsaw with a blade just long enough to go through. I usually cut them about 1 foot square, with rounded corners. Deburr the edges, so you done rip a hand open. Now you have plenty of room to get at everything. You can fabricate the cover out of plate, or attach strips under the edges of the hole to provide a lip for the cover to set on, and use the piece you cut out. You can go to a junkyard, and get them to cut you a piece from a wrecked truck, about 1 inch bigger than the hole. Prime , paint and attach with ss screws. You can make it neat enough to be almost unnoticeable. Next time you have fuel pump trouble, and you probably will, you can have it out in about 5 minutes! This works great on cars also. You wouldnt want to do it to a show truck, but again, you can make it as neat as you want. happy motoring
Later
Ed
