Old 10-27-2005, 03:06 PM
grace1 grace1 is offline
won't start
have a 92 PA, security code light stays solid w/switch in on position, ran code, no codes present, battery & starter ck'd good f rom shop's tester, tried to start by jumping solenoid it would start then dies immediately...could this be an ignition switch problem or more involved?
Old 10-27-2005, 03:42 PM
maxwedge maxwedge is offline
A990 racer
Re: won't start
Vats key chip type?, Try leaving the key on for 10 minutes, then shut off and restart, could be the wires from the ign key cyl to the connector at the lower column, they can break coming out of the key cyl. Try a second key possible.
Old 10-30-2005, 09:37 AM
Re: Re: won't start
Pretty day today, going out to try your advise, wish me luck!
