Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 10-27-2005, 01:11 PM
adm.asst. adm.asst. is offline
Unhappy 01 Dakota Code Problems
Seriously needing help from anyone willing to give it to me... Truck basically shutdown, had the codes ran, and of course the dealership is going to tell me I need a new transmission. Codes were p0442 which is evap leak and p0445 another evap leak, but then i got a code p1790 and p0734. Anybody know what is really going on? And do I really need new transmission or are they just trying to make me buy it anyway...
desperate
Old 10-27-2005, 07:19 PM
Dakota00's Avatar
Dakota00 Dakota00 is offline
Send a message via MSN to Dakota00
Re: 01 Dakota Code Problems
p-0442 (most of the times it's a loose gas cap, if not it needs replacing.)
p-0734 (Gear 4 Incorrect ratio) How's the tranny shifting??
p-1790 (TP (Electric) Circuit Malfunction)
Most likely it's a couple of shot sensors on the tranny, (my guess)
Disconnect the battery "-" cable, then turn the key in the ignition like your starting the truck hold 15-25sec.
Then turn key back off. Hook up the battery go for a drive and see if the codes return. This is the way of resetting the computer and codes.
Old 11-07-2005, 10:59 AM
fasstdak's Avatar
fasstdak fasstdak is offline
Send a message via Yahoo to fasstdak
What year/model is this on?
No...dealerships don't make you buy anything...but we have to go by DC's rules on warranty. If the truck has the extended powertrain warranty (either from DC or aftermarket)...you should be covered (deductibles may apply)
P0442 is more than likely the gas cap gone bad
P0445 - Check the lines to the purge solenoid...that's a Purge Solenoid Short code
The other two codes are definitely transmission related but resetting the codes via the battery also clears other information (such as OBD2 Monitors and Freeze Frame information that can be used to diagnose the transmission or other problems).
Chrysler/Dodge Certified Technician
1997 Dodge Dakota SLT - V6/5spd CC
Carillo Rods, KeithBlack Pistons (10.75:1), Ported & CC'd Heads, Crane Rockers (1.7:1), CompCams custom camshaft, Mopar Drive Gear, Smith Brothers Pushrods (7.050"), Ported Factory Intake, APS 50mm TB, APEXi SAFC-II Controller, JBA Headers, Magnaflow "TurboXL" Muffler, Cloyes True-Roller/Dbl-Row Chain with tensioner, etc. Dyno Proven: 214RWHP/238RWTQ (Without the Nitrous)
http://www.dodgetrucks.org/fasstdak
Old 02-03-2006, 02:14 PM
Afromankam Afromankam is offline
I had that same code, Pulled the rubber gasket off of the gas cap, soaked it in some Armor all to soften it a bit and then made sure that it was dry and clean before replacing it. Worked like a charm.
About a week later I got the same code, gas cap gasket was fine. Turns out that there was a crack in the Evap hose right by the testing plug, replacing the cracked section fixed the problem!
Old 02-03-2006, 02:20 PM
fasstdak's Avatar
P0442 and P0456 can both be caused by the gas cap (and yes...a small leak in the EVAP hose). Best bet is to check for any rust or gas in the center hole of the gas cap. If there is...replace it (cleaning won't work). If not...check all of the vacuum lines under the vehicle as well as under the hood.
Old 02-05-2006, 02:04 PM
wafrederick wafrederick is offline
Banned
For the evap code,use a smoke machine and they do work.You can find the evap leak real easy,the smoke comes out and there is the evap leak
Old 02-07-2006, 09:12 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Sounds like a slippage problem. the first and cheapest thing that I would try is a fluid flush/filter change.
P1790 - FAULT IMMEDIATELY AFTER SHIFT
When Monitored and Set Condition: P1790 - FAULT IMMEDIATELY AFTER SHIFT
When Monitored: After a speed ratio error is stored.
Set Condition: This code is set if the associated speed ratio code is stored within 1.3 seconds after a shift.
POSSIBLE CAUSES:
FAULT AFTER SHIFT
P0734 - GEAR RATIO ERROR IN 4TH
When Monitored and Set Condition: P0734 - GEAR RATIO ERROR IN 4TH
When Monitored: The transmission gear ratio is monitored continuously while the transmission is in gear.
Set Condition: If the ratio of the Input RPM to the Output RPM does not match the current gear ratio.
POSSIBLE CAUSES:
RELATED DTC'S PRESENT
RELATED PRESSURE SWITCH DTC'S PRESENT
TRANSMISSION INTERNAL PROBLEM
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
