| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
vaccum is this my problem
i have a 1995 tsi and it has a lot of shuf done to it. it has a 16g turbo that is brand new but it does not hit max boost (20lbs) untill like 4500-5000 rpms. the little 14b on my other car hits max boost (20lbs) at 3300 rpms. i was told i might need to clean my intake manifold because it might not be getting good vaccum. do you think that is it and if so how would you clean it with not having to pull the head. i have a 3in turbo back exhaust and a knn intake
Re: vaccum is this my problem
Do a search for leak test.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
boost leak...check your exhuast manifold bolts to make sure there tight also jpipe....
make a 10 dollar boost leak tester Jesse
Its a Dsm thing... <img src="http://www.dsmtuners.com/gallery/data/500/44010Pcdv0154-thumb.jpg"> |
Re: Re: vaccum is this my problem
yea so im dumb. i took some of the intake manifold cleaner and ran it throw the engine to help vaccum pressure. well when you do that it blows white smoke and more was leaking out of the front then coming out the muffler. so i replaced all the gaskets and the car runs great. it hits 20 lbs at about 3500rpms it is very fast and the blow off sounds great.
