I have another problem with my 95 blazer.
The service engine soon light came on and the rpm tack is jumping and its puttering and it doesnt want to take gas like it wont kick down. Maybe the cpi and knut kit?we are changing them friday oh should i chang anything else with them? If anyone can help please do. |
Re: 95 blazer missing and rpm tack jumping
-change the oil if the cpi was infact leaking; gas in oil = damage to bearings in the engine. -while swaping the cpi, it would be a good time to do a tuneup, if not already done, since u have the upper plenum off. -check the O2 sensors. if they are bad, they can cause the ECM to flood the engine and it will miss like crazy. -as for the check engine light, use a scanner to pull the codes and let us know what they are. im sure im missing something so someone will correct me, lol. hope i have been of some help.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
One little correction on ZL1"s advice, the o2 sensor doesn't have enough effect on the pcm to "flood" the engine, at worst it could force the pcm to reduce the fuel trim to lean it out, but would not cause the plugs to foul.
Re: Re: 95 blazer missing and rpm tack jumping
Did you check to see if you have the correct fuel pressure at the check valve. Also I would pull the error codes first. It also sounds like it could be your EGR valve giving you the trouble. Check your codes first. No sence in replacing parts if there still OK........
Since your SES light is set, have you pulled the codes? This would help us give you better advice...Advance or autozone can pull the codes for you..
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: Re: Re: 95 blazer missing and rpm tack jumping
Re: Re: Re: Re: 95 blazer missing and rpm tack jumping
All 3 types were available in 95
Re: Re: Re: Re: Re: 95 blazer missing and rpm tack jumping
Anyone Know? |
aux emissions controls cover codes P0400-P0499
Which code was it?
I dont know the guy at autozone just said aux emmision control.......
Thats why i dont like autozone! |
could it be sparkplugs?
1995 Factory Blazer Service Manual for sale, PM if interested. |
