Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-27-2005, 08:39 AM
pau143 pau143 is offline
Angry Wont start
Anyone out there please help!!! I have a 92 Bonneville SE. I was having a problem starting it at first. I could start it by turning the key off and on 3 times then start it, but now it just turns over and won't start. The floor boards on the drivers side front and rear had a puddle in it from the last rain, thats when I noticed the problem starting...always cranked right up before..Everything seems to be working Ie...windows, mirrors, seat...can hear fuel pump kick on. car has 120,000 miles. Did the paperclip in AB slot and got a 17 and 57 code. Any ideas or help would be appreciated. Thanks in advance!!! It is an SE, also when it finally did start it ran fine and started everytime after that all day just hard to start first time..
Old 10-27-2005, 08:50 AM
maxwedge maxwedge is offline
A990 racer
Re: Wont start
Do you have spark, any fuel pressure in the rail, spray carb cleaner into the intake see if it starts, all basics here. BTW, there is harness connector and/or ground under that area of the carpet, may not be related but check it anyway.
Old 10-27-2005, 09:33 AM
nemets88's Avatar
nemets88 nemets88 is offline
mine also had trouble starting...check the starter, also check the battery...believe it or not, if the positive or negative cable isn't connected tightly then it won't start. This cable should not be able to move at all...
Old 10-27-2005, 09:34 AM
Re: Re: Wont start
Thanks maxwedge I'll check for spark, got fuel pressure will try carb cleaner..and look for grnd and connector..
Old 10-27-2005, 09:36 AM
Re: Wont start
battery connections good!! and turns over great just wont start...Thanks nemets88
Old 10-27-2005, 04:10 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Wont start
I checked several lists for obd-1 codes on-line and they all skip codes 17 and 57. When I get home, I'll check my book and post what those codes are.
Old 10-27-2005, 06:19 PM
Re: Re: Wont start
Ok richtazz standing by.... By the way when I got home from work just checked the wires to cranksensor and cam sensor and fuel pump relay then pulled plug to see if sparking, sparked and started, put plug back in and car starts fine, till tomorrow am...
Closed Thread
