Go Back   Automotive Forums Car Chat > Volkswagen > Cabrio
Old 10-27-2005, 07:39 AM
zatman1 zatman1 is offline
Help ! Driver's side won't turn off alarm
Hi,
My daughter has a 99 Cabrio. Sometimes when unlocking the driver's side door the alarm sound when you try to start the car. If you go out and unlock thr doors from the passenger side, the alarm shuts off. It doesn't happen all of the time ..... usually at 7:00 in the morning when the neighbors are asleep !!
Also, one time in a heavy rain, the alarm went off on it's own.
We don't have an owner's manual, so the operation of the door locks is a little strange to us .... they open windows ....doors .... trunk ...
Thanks in advance ... Bob
Old 07-02-2006, 05:18 PM
I9er9er I9er9er is offline
Re: Help ! Driver's side won't turn off alarm
Hi have you done anything with the battery i.e. take it out, replace it, etc? Also are you using a DEALER programmed key? If you have any other problems my email is [email protected]
Old 07-03-2006, 09:13 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Pull back the rubber boot on the door hinge area where the wiring harness goes to. Check the wires for cracking or fraying - this can cause alarm issues.
It to me seems like the door latch microswitch is bad, unfortunately you will need a new door latch assembly ( $150-250.00)
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-26-2007, 02:50 PM
M75T M75T is offline
When the battery falls below a certian leval of cranking amps the alarm begins to freek out.
Check the battery first.
Also when you change the batery some times the alarm will not shut off. To turn it off, lock and unlock the trunk.
