Old 10-27-2005, 06:10 AM
hoodlegend hoodlegend is offline
what enclosure to use
hi ive got a panasonic CJHD253 subwoofer. it just came with very light specifications. i was wondering if anyone can tell me what type of enclosure i should use and how big. can anyone please help me?
Old 10-27-2005, 10:25 AM
vinnym86's Avatar
vinnym86 vinnym86 is offline
Send a message via AIM to vinnym86
Re: what enclosure to use
usually a qts of 4.0 and under is better suited for ported enclosures. I think that sub is under 1. i know there is a chapter on bcea1.com about enclosures, theres a calculater in there where u input some data and it recomends a box for you. still though, you can make w/e box u want really.
EDIT: ur qts is 0.37 Panasonic CJ-HD253
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
Old 10-27-2005, 01:58 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: what enclosure to use
that's .4, not 4
and that's only a suggestion, and it's only one of at least two. The other is the efficiency bandwidth product (EBP), it's the Fs/Qes
EBP <50 is sealed
EBP 50-90 is either
EBP >90 is ported
Most subs can be used in either, it really comes down to personal preference. With a decent sealed box you're going to get a relatively flat in-car response with just about any sub and no EQing. You aren't going to get a flat in-car response out of a ported or bandpass box unless you are purposefully shooting for that and have a shitload of room available (needs to be small and tuned very low, a small enclosure with a 15hz tune requires a HUGE port). Most ported boxes are going to give a large (~10dB) spike around the tuning frequency, if you like to have a small range of frequencies grossly overemphasized then a ported box is for you, if you like to have an even smaller range of frequencies overemphasized even worse then a bandpass box is for you.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-27-2005, 02:11 PM
vinnym86's Avatar
Re: Re: Re: what enclosure to use
Originally Posted by sr20de4evr
that's .4, not 4
my bad, i got mixed up somewhere
Old 10-30-2005, 03:35 AM
cheers bro, that help me. but i don't have enough specifications to calulate the enclosure required. can you help me please?
Old 10-30-2005, 08:06 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
that's .4, not 4
EBP <50 is sealed
EBP 50-90 is either
EBP >90 is ported
funny thing is i am pretty damn flat from 50Hz down to like 25Hz...(and dont tell me im not ive been on the mic and im pretty much +-3db from 30-50Hz and maybe about -4dB down to 25-27...which means i hover around 140dB)
which is a full octave.
my set up doesnt like to play over 50-60Hz so actually these "grossly over emphasized fequincys" which you are refering to that is rap music dont play well alot of times unless they drop low....which is why my set up carries so far (low frequincies travle further than higher frequincies though when driving away from an object the sound drops even lower so your ears loose sensitivity to the music, i know you knew that SR20 but some probably didnt or couldnt put a name to that phenomenon)
i need better midbass
Old 10-30-2005, 11:32 AM
vinnym86's Avatar
I can't find the technical specs to that sub anywhere, its not even on panasonic's website. try contacting your retailer, or maybe even panasonic themselves.
If you do get ur hands on some specs, here is a site that might help you out building your box:
http://www.carstereo.com/help/Articles.cfm
Old 10-30-2005, 12:03 PM
sr20de4evr's Avatar
Re: Re: Re: Re: what enclosure to use
Staying within a 6dB window in less than an octave is not flat....staying within a 1-2dB window for 2+ octaves is flat, and most decent subs in a reasonably thought-out sealed box will give you that.
'01 Black Sentra SE
'05 Silver WRX STi
Old 10-30-2005, 10:01 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Your XXX comps dont give you enough midbass???
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 10-30-2005, 11:45 PM
sr20de4evr's Avatar
RE comps, not XXX
the XXX comps aren't even available yet
'01 Black Sentra SE
'05 Silver WRX STi
Old 10-31-2005, 04:24 PM
Mannyb18b's Avatar
Ya, but I thought CB bought the XXX mids and went active........
Alpine H/U-
CDT EF-61's
NSB-100
Old 10-31-2005, 08:47 PM
CBFryman's Avatar
Banned
that was noah
Old 11-01-2005, 01:48 AM
Mannyb18b's Avatar
oh, hmm... well is the loss of midbass that bad cbfry? im thinkin of getting a pair, but not so sure now. How do they keep up with the 18 cause i will have a similiar setup
Alpine H/U-
CDT EF-61's
NSB-100
Old 11-01-2005, 01:27 PM
CBFryman's Avatar
Banned
its isnt that the RE'sare bad, its that i have them getitng maybe 15-20w on a cheap sony amp and i have 0 deadaning in my doors and that really XXX's or Koda's are all there are that can keep up with an Ava18.
i can turn my bass knob down to about 1/4 and the whole system sounds quite nice actually. rock, country, anything...
