Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-27-2005, 03:46 AM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Exclamation recently got cold weird engine noise need help
it recently got cold here, and i'm hearing a weird clicky clank sound coming out of my value cover on idle.... any ideas?
just started as it got cold, like 30's... tons and tons of rain. I just had a headgasket replaced by the dealership 2k miles ago. so they ripped the valve cover off and it looked fine then.
might maybe a belt not sure its dark. can only hear on idle, barly hear when hood is closed, louder when opend.
sounds like a computer hard drive clicking only louder.
any advice?
Something new is coming...
Old 10-27-2005, 07:30 AM
TreeFrog's Avatar
update. its light outside now
the circled area is where sound is coming from, NOT the head/vaule cover its the itake manifold, coming from the drivers end of it
i can hear it under car( could be from down there some where)
can't hear when hood is shut, unless you put head under car
car starts (its cold here) 1200 warm up rmps, no sound
car warms up, idles JUST above 500pms, and sound starts
Old 10-27-2005, 08:12 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Your idle is a bit low when warmed up. Should be around 750-800 rpm. I would guess and say it has something to do with idle if it is idling that low.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
