Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-26-2005, 10:41 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
97 smelling gas after driving found problem
Hello
I just wanted to post about a gas leak that I found tonight. For the past couple days I've been smelling gas when I get out of my car. I fianlly took the time to put the car on the ramps and take a look. The fuel tube from the tank to the fuel filter was leaking! I moved it to one side a bit and gas just ran out.
I'm not inpressed with GM's plastic fuel line connections! Yes they're quick to put together and yes it did last 8 years.
I went and got 2' of 3/16 ID fuel hose, clamps and put the hose in place of the plastic tube. Works great. No more fuel smell! While I was under there and had one end of the fuel filter off so I replace the filter. It looked orginal. (106,000 miles)
Just thought I'd share this.
Regards
Dan
Old 10-26-2005, 10:59 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 97 smelling gas after driving found problem
Thanks for sharing. This advice should help someone with the same problem.
I also, have never been a fan of the quick connect plastic fittings or plastic anything for that matter. I know it is cheaper and lighter than metal, however not as durable. I was perfectly happy with the way they built cars back in the "good ole days", before plastic became a commodity.
Old 11-22-2007, 08:34 PM
Divorce Court Dan Divorce Court Dan is offline
Send a message via AIM to Divorce Court Dan
My buddy is having a leaking fuel line in the engine compartment right where the lines connect to the fuel rail. Looks like the plastic fittings. Can I get one of these fittings at the local auto parts store?
Old 11-22-2007, 09:09 PM
HotZ28's Avatar
AF Moderator Elite
Unhappy Re: 97 smelling gas after driving found problem
It would be better to start a new thread with this question.
Please Read: Posting in Closed or Outdated Threads - LeSabre
Thanks for your cooperation.
Closed Thread
