Old 10-26-2005, 05:10 PM
dobermankid dobermankid is offline
Send a message via AIM to dobermankid Send a message via Yahoo to dobermankid
03 Cavalier Ls Air Control problem
When my heater or AC is on it will only blow out through the front vents. Even when I turn the selector to blow on the windshield or the floor, it still blows out through the front vents. The selector feels like its broken because when i turn it to either end it seems to sling back towards the middle, but i am not sure if that is the problem. I took it to the dealership and they said it was the vacuum hose and others say it could be the actuator. PLEASE HELP!!!!!
Old 10-26-2005, 08:21 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: 03 Cavalier Ls Air Control problem
I know some cars have a cable to switch to diffrent things so look under you dash and look for any broken cables.
Old 10-26-2005, 08:49 PM
Thats what I think it is. I looked behind that area, near the floor board, and when I turn the knob, it looks like cable seems to be loose. I'm not too familiar with these things. Do you know where the other end of the cable is?
Old 10-26-2005, 09:04 PM
97cavalier's Avatar
One end is attached to the end of that nobe and the other is attached by the fire wall i think, to the lever that switches the vents and ect.
Old 10-26-2005, 09:09 PM
what is the "fire wall"?
Old 10-26-2005, 09:11 PM
97cavalier's Avatar
um it is thw wall, if you open your hood, it is the wall that seperates you motor from your inside of you car. If you look under your das it is the wall that is there.
Old 10-26-2005, 09:16 PM
ok, thats what I thaught. So do you think that its not the vacuum hose or the actuator?
Old 10-26-2005, 09:19 PM
97cavalier's Avatar
actuator? is that the motor that switches the vents?
Old 10-26-2005, 09:25 PM
Not sure. Not familiar with this stuff. But it sounds like its the cable.
Old 10-26-2005, 09:32 PM
97cavalier's Avatar
Re: Re: 03 Cavalier Ls Air Control problem
well if the actuator is the motor that means is either runs on electric or vaccum. So it could be both. I would just do it step by step, frist move the nob and see if you see the cable moving, and if it is loose.
Old 10-26-2005, 09:35 PM
Its loose.
Old 10-26-2005, 09:58 PM
97cavalier's Avatar
Its loose.
ok, there sould be a clamp some where on the fire wall when the cable attatches with the cable. that might be lose and the hole cable is sliding. try to find that and tighten it up.
Old 10-27-2005, 08:04 AM
I'll do that. Thaank you!!!
Old 10-27-2005, 08:19 PM
Do you know how to take the panel off to get begind there? Does it just pop off? It seems like it does, but I don't want to break it.
Old 10-27-2005, 08:59 PM
97cavalier's Avatar
panel to get where?
