flashing temp and oil LEDs
This car has been great to me in the past. A new and very annoying thing started to happen. I check everything (fluids) weekly. I maintain it.
Mornings: I start it--ok. 3 mins later sometimes less, Then it begins to misfire, and the oil and temp LEDs flicker like a "short" is present. This makes the car run real, real bad. Ive tested alt, tested and replaced the batt. Im getting 14.5 v output- which fades to 13.7. It will maintain 13.0-13.5 when hot. The battery led lights only with IGN on, engine not running-goes off when started. Ive checked grounds, bolts, harness, blue wire from alt, hot to starter, pos and neg connections.I had the dash out, while in there I fixed the temp guage (resolder) hasnt worked for years. I also have a SUN tune mounted inside the car console as well. Its never done this one. I cant make this obvious big time trouble disappear. Any advice guys? |
Re: flashing temp and oil LEDs
Re: Re: flashing temp and oil LEDs
1.coolant sensor, 2. 02 sensor, 3. cat, 4.entire new distributor, 5. coil w/PoS , 6.cap & rotor. |
Re: Re: Re: flashing temp and oil LEDs
