Old 10-26-2005, 03:29 PM
SilverstoneXJ SilverstoneXJ is offline
After Rear Main Seal - Car won't move in gear
'93 Talon w/ auto transaxle
Well, I got the rear main seal replaced, and the beater runs and holds it's oil. But, when I out it in gear... nothing. I was careful to make sure to seat the converter back in before installing the tranny back in place. Could it be something electrical?
When I refilled the tranny with the recommended 3 quarts, it's no way overfilled. I'm gonna drain it back down to the proper cold level. Definately hope I don't have to drop it back out again.
With the key in the ON position, and I shift into Drive I can hear a little noise coming from the tranny. Almost like a little motor or something clicking.
'93 Eagle Talon DL
The $400 Beater
Old 10-26-2005, 04:04 PM
The little clicking sound I hear in the tranny happens like this:
When I shift into Reverse - The noise happens for about 3 seconds and quits.
When I shift into Drive - The noise happens for about 3 seconds and stops. Then about two seconds later it starts again and continues non-stop.
I reversed the two larger electrical connectors around and the noise doesn't happen at all.
This is why I think it may be an electrical issue.
Any suggestions?
'93 Eagle Talon DL
The $400 Beater
Old 10-27-2005, 10:03 PM
Got a few ideas today from local tranny shops to check out. One place said to check the fluid level with the car off. Then note where the level was while running. The level should drop down some. Well, mine didn't, which I'm hearing means the pump is shot. Not something I wanted to find out.
Old 10-28-2005, 02:17 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: After Rear Main Seal - Car won't move in gear
so cant you find a junk car with a tranny witha good pump for cheap?
Old 10-28-2005, 10:58 AM
ned032002's Avatar
ned032002 ned032002 is offline
Are you beating yourself up over buying the beater yet? Yeah just do as EDMUND65 said and try a junk yard. GL
Old 10-28-2005, 11:32 AM
Re: Re: After Rear Main Seal - Car won't move in gear
A little. Should have tried a gear when I ran it before buying. Yeah, I can get one from a U-Pull-It place down south for $70. Just wanting to make sure this one is shot. Wouldn't want it to be something small and stupid, and I go through the hassle of pulling the thing back out when I didn't need to.
'93 Eagle Talon DL
The $400 Beater
