Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-26-2005, 02:19 PM
getfreshco getfreshco is offline
wierd feeling? sound?
when ever i turn my steering wheel i get this sluggish feeling ...and this power wheel sounding sound? any idea what it could be?
Old 10-26-2005, 03:14 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: wierd feeling? sound?
Sounds like the power steering pump is going.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 10-26-2005, 05:49 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
The belt going around your power steering pump might be loose, thats the problem mine had, and it was acting exactly like you described. But I'm also still wondering does it act this way when you turn the wheel any amount, or does it act this way when you turn the wheel almost maxed one way or the other (hard steer)?
Old 10-26-2005, 07:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Check the fluid level. If it's a howling/groaning noise, the pump could be cavitating due to a low fluid level. If it's more of a scream or shreik, or a dog yelping noise, then check the tightness of the belts.
If it's doing that howling/groaning cavitation sound, and the fluid level is fine, then it might be time for a new pump.
Old 10-26-2005, 08:00 PM
its fine until i make a turn (max) then it gets sluggish ......i put it in park and then open the hood .....get back in the car its fine!?!?!
Old 10-26-2005, 08:30 PM
silicon212's Avatar
Confoundingly Lucid
Could be a loose belt then. Check the tension. If it's a serpentine belt, you may need to check the tensioner.
Old 11-01-2005, 03:47 PM
PeteA216's Avatar
The engine on mine gets sluggish too... it always has. When you turn the wheel the pump helps using turning power from the engine. When you max it out the pump is trying to help you turn more, and with the wheel maxed out the pump works extra hard and takes a lot of the power from the engine. If you have a 305 the power drain will be much more noticable than if you have a 350.
