Old 10-26-2005, 01:37 PM
blazer_guy86's Avatar
blazer_guy86 blazer_guy86 is offline
What is a coolent temperature sender???
This whole engine temperature is really giving me #@&& lately! My engine is still running way too cool (155 or 160). I have replaced the rad cap, did a complete flush and replaced the stat with a 195.
BlazerLT said that it may be a defective coolent temperature sender or something. But what the crap is this? Is it hard to replace?
Old 10-26-2005, 01:42 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: What is a coolent temperature sender???
Its only like 10 bucks it screws into the block and then the electric connector gets plugged onto sender.
http://www.partsamerica.com/ProductD...pe=290&ptset=A
http://www.autozone.com/servlet/UiBr...3d8012a601.jsp
Tells you where to look
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 10-26-2005, 01:50 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Before swapping it out, I would look at borrowing a scanner that does live data. The reason being that our trucks use 2 different temp sensors. One for the gauge, and one for the ECM. If the ECM is running the same temp as on the gauge changing the sensor won't help, if there is a vast difference (lets say gauge is 160 and ecm shows 200) then you know it's the sensor. This way you won't waste money.
Also are you getting heat?
Old 10-26-2005, 03:22 PM
blazee's Avatar
blazee blazee is offline
Problem?
97+ no longer have the sensor on the intake. I believe that the gauge and the PCM share the one between cylinders 3 and 5 on the block.
Old 10-26-2005, 03:24 PM
rlith's Avatar
I thought that was for 98+ when they changed the ECM
Old 10-26-2005, 03:39 PM
blazee's Avatar
Problem?
You're right it was 98+. I was going to put that 97 was the last year, and after rewording it, I messed up.
Old 10-26-2005, 03:43 PM
rlith's Avatar
Re: Re: What is a coolent temperature sender???
Banned for 2 weeks!
Old 10-26-2005, 03:59 PM
blazee's Avatar
Problem?
Re: Re: Re: What is a coolent temperature sender???
Banned for 2 weeks!
Okay, I'm sorry..... I'll go, now.
At least I'll admit when I mess up. I'm sure that you've seen that some guys, here, will argue about it even when they know they're wrong.
Old 10-26-2005, 07:36 PM
lol.i missed the ball forsome reason lol i gave tbi instructions hangs head and walks away lol.See i used it 3 times in one sentence
Old 10-26-2005, 08:31 PM
yes i am getting heat but i know it's not as hot as it should be. Gas mileage ain't the best either.
Old 10-26-2005, 08:34 PM
rlith's Avatar
Another thought just came to mind... I wonder if your clutch fan is disengaging properly. If it's constantly engaged it could be cooling the engine too much....
Old 10-26-2005, 08:36 PM
He should go with the taurus fan.I cant wait till my duals get wired up the week of the 13th w 5.7
blazee's Avatar
Problem?
....and reducing his gas mileage.
Makes sense.
Old 10-26-2005, 08:43 PM
I do have access to a scanner, so i'll do that tomorrow. But i really do think that the gauge is right cause like i said my heat doesn't get as hot as it should.
Old 10-26-2005, 08:45 PM
Clutch fan is operating normally.
