My brake light comes on after starting the engine. I replaced the pads, master cylinder, and wheel bearing but the light is still on. :-(
I dont know where to go from here. The weird part is that when I engage the parking brake, the low traction (or traction off, dont really remember what the light actually says) comes on. Any help will be much apreciated. Thanks in advance. |
Re: Brake light trouble on 99 century
have you tried bleeding the brakes? if there is air in the line the brake light will stay on.
Re: Re: Brake light trouble on 99 century
How do the brakes feel when driving it? The TRAC light coming on when you apply the parking brake is puzzling. Also the BRAKE light indicates the parking brake is engaged in addition to a possible hydraulic system malfunction.
The brakes feel and perform well as far as I can tell. I haven tried the bleeding like it was sugested before.
Re: Re: Re: Brake light trouble on 99 century
You can go with the bleeding suggestion. I'll review the GM service manual and see what's up with the idiot lights. At any time do you get the ABS light? When the master cylinder was replaced did you install a new level switch. If it's stuck or the brake fluid level is low it will trigger a BRAKE light. Sounds like there might be an electrical problem with the switches and warning lights.
Re: Re: Re: Re: Brake light trouble on 99 century
Hello, I again thank you for your help. My brother replaced the master cylinder when I was visiting home in Iowa, I am not sure if he installed a new level switch but I can call and ask. Thanks again |
Re: Re: Re: Re: Re: Brake light trouble on 99 century
One way to test it is to simply disconnect it. If the BRAKE light goes out then thats your problem. When the level is low the sensor passes a ground to the BRAKE light. When the level is OK the sensor provides no ground to the light and it should therefore be off. Also test your emergency brake with ignition in run but not start. When depressed you should get a BRAKE light. Released it should be extinguished.
Also, I never get the ABS light. The only weird light is the "Traction Off" when I engage the parking brake. I know it sounds weird but thats what happens. |
Re: Re: Re: Re: Re: Re: Brake light trouble on 99 century
