Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-26-2005, 11:16 AM
Snif_1 Snif_1 is offline
Question 99 rodeo 2wd auto only reverse 6cyl
Help 1999 Rodeo 2wd 6cyl only reverse
Vehilcle has just over 100k and was shifting fine and just lost drive all at once.has a very strong reverse. i have replaced the fluid and filter. while on the lift, putting vehicle into drive gear allowed the wheels to move as they should. note apon acceleration wheels seem to accelerate as if i would put in back on the ground i would have fixed the problem...Not the case. When placing vehicle on the ground i only had reverse with a very slight movement forward. while testing in the air... when moving the shifter from low to nuetral vehicle would stall out. vehicle needed jump box to start...the only light on is abs but i dont imagine they are related in any way.I am hoping for electrical solution.. can you help?
Old 10-26-2005, 11:45 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 99 rodeo 2wd auto only reverse 6cyl
could be the range selector ... see the faqs link
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 10-26-2005, 06:49 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
when servicing the trans did you notice any brass shavings in the pan
if you did not remove the pans remove the front pan the little one look for debris and or brass shavings let me know what you find
Old 10-27-2005, 03:14 PM
yes, I removed both pans and no evidence of any shavings in small pan. if there were shavings i missed them. the filter and main pan had what you would expect..ty
Old 11-01-2005, 09:42 AM
Re: Re: 99 rodeo 2wd auto only reverse 6cyl
removed selector cleaned connection and reassembled... while checking wether it worked or not we bumped the winter button. we now know when the vehicle is in the winter mode it has forward gear(drive only) and reverse. when switching from winter mode to normal mode we return to only reverse. any suggestios?
