Replacing the oil cooler lines to fix oil drips...
Is replacing the oil cooler lines an easy job and one that i could do myself, or do you have to take it in somewhere? Also, what tools do you need to install? Do you have to drain the oil? etc...
Re: Replacing the oil cooler lines to fix oil drips...
You can do it yourself... Really all you require is a 13mm box wrench or 13mm socket and a long extentsion with a swivel for the back one... and some patience...The new lines will also come with new crush washers, USE THEM!
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Where do you buy these new lines? and how much do they cost?
Dealer.. about 60-70 bux..
do you reccomend buying the dealer parts, or i just called on some Dorman replacment lines for 40 bucks?
According to United Auto Parts, Dorman makes a replacement for the oil cooler lines for $40 , i guess i'll try these instead of the $85 Dealer lines
http://www.rockauto.com/catalog/cata...&parttype=5516
I bought a set for my 98. They are a lot cheaper but they aren't made as well as the originals. One issue with mine was that the factory used a 90 degree connector on the line going to the top of the oil cooler. The dorman uses a 90 degree bend.... the bend sticks out further and rubs the airbox, it could possibly rub a hole in the line. I put a piece of rubber hose over mine to protect it and haven't had any problems. |
How long have they been on?
I put them on 2-11-05. 32,000 miles ago.
I recently replaced the oil cooler lines in my 98. It took about an hour to do. I got mine from napa for about $40. But i had to give them a part number, they couldn't look it up by vehicle. But about the air box, i wouldn't have a clue considering i have a cold air intake. good luck!
Go to "LMCTRUCK.COM" order a catalog . It has an excellent exploded view of our autos . With all part descriptions and numbers . And reasonable prices before shipping . Rob
Wait are their 2 separate parts? i bought one part that has 2 lines on it that goes back near the transfercase, and i get the skid plate off, then i see another one going up alongside the radiator? so are there 2 parts? and a total of 4 lines?
Re: Re: Replacing the oil cooler lines to fix oil drips...
yeah they are both moist with oil and drippy
