high idle on cold engine....
MY engine will rev up way to much. I know that isnt normal and if it is...my engine gonna mess up this winter. In the mornings when im going to school my stealth will turn on to 2000 rpms or a little higher. Not only is it annoying BUT i know it isnt good for a cold engine. I have to wait a good 4 minutes BECAUSE if it doesnt warm up a little, it wont shift!! ANyways...any help is aprreciated
Re: high idle on cold engine....
The high idle is because the car has heated oxygen sensors... it will idle the car high until it has reached operating temperatures... I'm guessing that you have an automatic... You may wanna have the transmission checked out (sry, I don't know enough a/b how ATXs work)
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
yep its an auto...i hope it wont take another of my checks...:|
mine idles high as well when first cranked. its pretty normal for them to. mine is usually around 2200rpm. my transmssion acts wierd too when its cold. it can go in reverse. but once i put it in drive to take off it will just rev high an then click into gear an jump really hard.. sometimes will jump real hard. fall out of gear, an jump back into drive numerous times. i find it easier jus to take off in L.
so is it normal for our engines to do that??
how high does urs rev exactly?
the transmission problem described by modifier sounds like a torque lock-up converter... my friend had the problem on her atx Buick Regal... the solenoid went bad, and it kept the torque converter locked up and would keep the car in third gear (this was after it warmed up though)... and when stopping for lights and stop signs, the car would actually cut off... they'd have to wait for the vehicle to cool down, for the solenoid to work right and start the vehicle...
it may be the transmission computer also... but like I said... this is all speculation, b/c I don't know enough a/b atx transmissions to tell u but the high idle is normal... give the car 2-5 mins... and the idle should drop to normal... then drive the car... that would be best as it would allow all the fluids to heat up... give this a try for a week or so... and let me know what happens... within that time I may have had a chance to look into the problem a little more...
yea my tranmssion problem isnt as bad as that one. its like right when i start it up an put it in drive it will go.. but if i wait a few minutes it will kinda slip an not go anywhere an click into gear. also if im getting on it at high speeds it will slip outa gear an rev near red line. ive actually had it go up to around 8500 rpms once... scared the crap outta me an there was an imediate burnings smell of course. no harm was done to the motor tho. jus the transmission got burnt pretty bad.
MIne iwll rev up to a little over 2000...only when the engine is cold. BUT wont the hard revs do a number on the valves and block? i hurd its bad for them when the engine is cool.
Re: Re: high idle on cold engine....
im getting rid of my steath i got a AWESOME offer by some guy that wants to buy it for his daugher
Re: Re: Re: high idle on cold engine....
Re: Re: Re: Re: high idle on cold engine....
