4 wheel mode pulling to the right.
Hi people, i been having this problem for a long time, but never found an answer to it. I have a 1995.5 honda passport, when i engage it into 4wd high mode on wet road, i feel it pulling to the right, my aligment is fine in 2wd mode. I have to turn the wheel to the left to correct it, and it feels really heavy, like the front right tires is gripping more than the front left. I put it in 4wd once in a while in on wet surface for a few min just to get everything lubed. Thanks for all you help.
Do you have auto-lock hubs or is it shift on the fly?
Your tires are not all the exact same diameter causing the driveline to bind.
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Re: 4 wheel mode pulling to the right.
To see if Rodeo02 is right, try swapping the front tires and see if the problem moves to the other side?????
1993 Rodeo, V6, 3.2L, 4x4, 5 speed 130,000 miles Chicago, Illinois |
Re: Re: 4 wheel mode pulling to the right.
Re: Re: Re: 4 wheel mode pulling to the right.
2000 VW New Beetle TDI 2007 Honda CR-V |
Re: Re: Re: Re: 4 wheel mode pulling to the right.
Re: Re: Re: Re: Re: 4 wheel mode pulling to the right.
G/luck Joel
