Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 10-25-2005, 11:22 PM
Hudini Hudini is offline
Dome light flutter
I have a '95 Del Sol Si. The dome light seems to have a mind of its own. When in the middle position the light will flutter on and off when you hit a bump. I am suspecting the door switches of course, but maybe a loose ground somewhere. The really strange part is that the light can come on by itself when the car is sitting in the driveway overnight. Has anyone experienced something like this?
I am also having an SRS problem. The SRS control module turns on the light on the dash, but when I go to pull the code the SRS light does not blink. When I reset the control module and check the codes it shows no code (steady flashing, as it should).
Is it possible the dome light and SRS control module problems are related? Maybe a shared ground?
Any help is appreciated.
Old 10-27-2005, 01:06 AM
91civicDXdude's Avatar
Re: Dome light flutter
my dome light in my 94 del sol VTEC does the same thing. i just usually turn it to the "off" position
Old 10-27-2005, 11:07 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
I think it's a sol thing.. just about everyone I know has a light flutter. The rubber on the switch wears down, and let the strobe show begin! Usually more of a pain to fix than it's worth... I just leave it off until I need a light, then I turn it on. It's not like it's *that* far too reach...
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 11-03-2005, 02:23 PM
gomez268 gomez268 is offline
i have the same problem, its the switch on mind, all i did was put some paper to fill the tip of the boot as a temperary fix. to lazy to go to the dealer to buy the switch. i think when i check it was either 7 or 14 bucks dont remember.
