Old 10-25-2005, 11:09 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Removing ABS?
Hey guys, my ABS is being a real B@$tard lately, the light stays on almost 24/7 now and sometimes while accelerating it lurches etc. Anyways i was wondering if there is an easy way to remove the ABS? Would taking out the fuses or pulling out the sensor plugs stop it from working or wud that make it even worse. Would there be a big difference if i didnt have the abs? Its prolly not good for the car having it kick in while moving fair speeds without braking. Anyways any help appreciated. Thanks
Old 10-26-2005, 08:08 AM
cdru's Avatar
cdru cdru is offline
Re: Removing ABS?
You know that light is on for a reason. Fix the fault and the light goes out. A shop should be able to read the code and tell you why the light is on.
My guess is that you have a wheel sensor that is going south. It either never works, or occasionally works (when you get a lurch). Without that sensor working correctly, the ABS system has no idea when a wheel has locked up (or is about to).
Vinyl adds horsepower, right?
Old 10-26-2005, 08:45 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
you could take the fuse out and that would disconnect the abs, but that light would be permanently on
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-26-2005, 09:05 AM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
Re: Removing ABS?
some black tape, just tape it right over the light.
on a serious note, you should just get it checked out, it would prob just be better to get it fixed then removing it.
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 10-26-2005, 12:20 PM
Re: Removing ABS?
Yeah but see i got this car for free, and i dont feel like putting to much money into it, it has high km's and im just gonna baby it and go cheap, unless something is serious, this dont seem to serious to me. Unless u think i really shud get it fixed, how much do u think it would cost? Thanks
Old 10-26-2005, 07:16 PM
Re: Removing ABS?
Also, Jake do u mean pull the big ABS fuse from fusebox? And are u sure that wud disable the ABS?
Old 10-26-2005, 08:33 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Thumbs up Re: Re: Removing ABS?
it will because if you pull the main abs fuse that means there is no circuit going through. Which means no power to the abs. But i would get it fixed. Even if you got it for free, that will not matter when you have to pay a bill to get somones car fix because you accidentally ran it to the back of there car. It is hard to know when to hit the pedal when you don't have abs it will not have alot of pedal and after you go so far down it will make a quick stop. So i would get it fixed.
Old 10-26-2005, 09:20 PM
lilrogue78 lilrogue78 is offline
Re: Removing ABS?
in my jeep i have a pair of wires going to my abs fuse and to a toggle switch to turn it on and off for doing fun shit like burnouts the abs makes it a bitch if ustart spinning the tires the breaks disengague but with it disabled its a blast :P just my $.02
Old 10-26-2005, 11:16 PM
Re: Removing ABS?
97cav, most cars dont have abs tho, how do they cope? Im debating of getting it fixed, but how much wud it run me do u think? If there is parts involved, i have a friend whos dad is a hvy duty mechanic and will do/install everything for free so.. Thanks
Old 10-27-2005, 04:29 PM
97cavalier's Avatar
alomost all cars have abs now, alomost all 90 and u do.
Old 10-27-2005, 04:30 PM
97cavalier's Avatar
Re: Re: Re: Removing ABS?
and with the asb, do you have any break pedal? or does it go to the floor???
Old 10-29-2005, 01:31 PM
chevyguy93 chevyguy93 is offline
Re: Re: Re: Re: Removing ABS?
You will have some brake pedal. The thing is, no matter how hard you press it, (if breaking on ice), it wont make a difference. When the abs kicks in, it does the breaking itself. So if your on ice, and your pushing the brake as hard as you can, it wont make a difference if you to were press it normally.
ABS can be quite a life saver. I know in the other car's ive owned, it's stopped me from sliding into oncomming traffic in the winter, etc. And the abs in my cavalier doesnt work right now, so i'm looking into getting it fixed too since winters only a few weeks away here :S. Last year i went without it and almost had a heart attack from almost sliding into stopped cars. crazy stuff.
So yea. Get your abs fixed. They invented it for a reason!
2003 Grand Prix GT
1993 Cavalier 2.2L
