Old 10-25-2005, 09:48 PM
frizbal frizbal is offline
Send a message via MSN to frizbal Send a message via Yahoo to frizbal
Question blinker not blinking
I have a 96 firebird 3800(dont think it matters for blinker trouble but oh well lol). My left side rear blinker doesn't blink when i flick on the turn signal. Instead it just stays solid until i turn it off. rarily it will blink but it blinks...stays on for about 3 seconds... blinks... and repeats. Does anyone know this problem? All the bulbs light and work. Please help!
Old 10-25-2005, 10:02 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: blinker not blinking
did you say all the bulbs are good? if not that usaly means there is a blown bulb. If that is not it, it MIGHT be the blinker mondual. I don't think that would be it tho.
Old 10-25-2005, 10:21 PM
yes all bulbs work. but it still somewhat blinks, would that mean the mod is GOING to go out or what?
Old 10-26-2005, 02:32 PM
gmack221's Avatar
gmack221 gmack221 is offline
Does both side not flash, or just one, usually when you have one stick on its a bad bulb, corroed socket, or a turn signal relay starting to go out.
Try a turn signal relay first its cheap, sometimes they stick and will not flash. The relay is the annoying clicking you hear when you turn on the turn signal or 4-ways, it should be under the dash (usually on the drivers side by the column). Easiest way to locate is get one side to work, then listen for the clicking. Sometimes they use one relay for the turn signals and one for the 4-way-flashers, they are usually close to each other and if you can't get the turn signal one to click you can get the 4-way flashers to click. If its always clicking then you have a problem with bulbs, light sockets, or wiring.
Old 10-26-2005, 09:47 PM
if the relay go's out wouldn't it make both stop blinking instead of just one? cause the right side blinks fine but the left dont. and if the socke was bad would it still be able to light up? cuz mine duz
Old 10-26-2005, 09:54 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
replace the flasher unit with a heavy duty flasher unit. If you look you will probably notice that your front left is also not blinking. Firebirds have a mysterious wiring problem that after awhilewont let the front left blinker work properly. Just replace your flasher now iwht a heavy duty flasher and ur rear blinker will blink, but your front one still wont.
Old 10-27-2005, 07:11 AM
gmack221's Avatar
when my flasher (turn signal relay) started to go, it would stick when I turned on the right turn signal but was fine when I turned on the left one. Don't claim to understand it, just the way it happened on mine, eventually it quit working on both sides. For a heavy duty flasher your looking at about $10, they are cheap, I would try that first.
Old 10-28-2005, 11:05 AM
Re: Re: blinker not blinking
both blinkers on the right side dont work. do the flashers work the back and the front? or do they work the left side and the right side?
Old 11-04-2005, 11:30 AM
traskin traskin is offline
To blink, or not to blink...
I had this problem on my 94, and the guilty party was a faulty ground in the tail light. My lights would blink right, blink slow, not blink, or just blow. Along with that, the ABS Inop light would come on, and the cruise control wouldn't work. I fixed it by hardwiring a ground to a bolt in the trunk.
Hope this helps!
Old 12-27-2005, 06:23 PM
Crazygoat Crazygoat is offline
Im having this exact same problem with my 97 firebird but on the right side. My front blinker blinks but not my rear. When i turn on the signal itll maybe flash for a few seconds then stay solid.
Old 12-28-2005, 11:00 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Anyone got built up moisture in your rear tail light?. This usually causes lights to blow and could cause a short if the water builds up enough. If any of the lights to the side you are trying to signal are not making good contact or if one is blown or if you have a short in one wire to that side. None will blink.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
