Old 10-25-2005, 10:43 PM
misfits808 misfits808 is offline
91 s-10 truble
i have a 91 s-10 thats been nothing but truble since i got it right now its idleing up and down then when i push on the gas it hesates then starts to go up in rpms and when driving it it bucks really bad when i push the gas its like it loses all power the slowly gains it
Old 10-26-2005, 02:15 AM
OverBoardProject OverBoardProject is offline
Banned
Re: 91 s-10 truble
The 2 things that I would do is first check for any vacuum leaks. If the motor rev's up while spraying WD40 onto a vacuum conection you found a leak.
And if that doesn't work do a complete tune up.
Including change the fuel filter.
If you haven't changed your fuel filter in a while change it anyways.
The best way to burn out your very expensive fuel pump is by letting the fuel filter get plugged
Old 10-26-2005, 02:42 AM
i have changed the fuel filter along with the tps,fuel injector,igintion mod,cap and roter,memcals comp, and still nothing it runs the same
Old 10-26-2005, 02:43 AM
oh and ive changed the fuel pump
Old 10-26-2005, 02:51 AM
Banned
Re: 91 s-10 truble
Oh, Welcome to the forum! I hope that you check in from time to time.
It's nice to see someone that does a tune up when it might help.
It still sounds like a vacuum leak to me, so that is where I would start.
I didn't really think that a tune up would help, which is why I didn't write it down first.
But it does solve most problems that people have
Old 10-26-2005, 03:23 AM
ive all ready checked for vacum leaks
when i did a self diagnostic it came up with tps low voltage but then i removed the ground cable from the battery and ran the truck for 20-30 mins then did the diagonstic agin but nothing came up
