Old 10-25-2005, 07:44 PM
IceMan7281 IceMan7281 is offline
Send a message via AIM to IceMan7281
Help my truck with it's squeaking problem
I have a 2001 blazer ZR2 and the rear window squeaks wicked bad. is there anything i can do to stop the squeaking. or at least surpress the squeaking. please help me out cuase this problem is getting on my nerves thanks.
Old 10-25-2005, 07:46 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Help my truck with it's squeaking problem
you sure it isn't the cargo shade.
Mine rattles in the winter.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-25-2005, 09:15 PM
swalt's Avatar
swalt swalt is offline
Check to make sure the striker plate on the rear latch is lined up. You will see wear on it if it is not. Lube it well (grease it). Use a good quality silicone spray on the weather stripping window seal every week or so and it should take care of the problem. Mine usually gives me problems in the winter.
Old 10-26-2005, 10:00 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Help my truck with it's squeaking problem
Should you be using silicone on rubber? I was told to use a petroleum jelly seeing it will not crack or degrade the rubber.
Old 10-26-2005, 12:02 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
i had the same problem like a week ago. i too put some petroleum jelly of the seal and the noise is gone completly..
Old 10-26-2005, 12:08 PM
swalt's Avatar
Re: Re: Re: Help my truck with it's squeaking problem
Petroleum jelly will work also. A lot of the dealerships use dry silcone spray to prevent the weatherstripping from sticking/hardening. I have actually found that the new "JigALoo" stuff you can get at Canadian Tire/Home Depot works very well and doesn't leave a mess.
Old 10-26-2005, 12:31 PM
BlazerLT's Avatar
AF -Advisor
I would avoid jigaloo seeing it is a petroleum distillate that actually over time will dissolve your rubber and harden it.
From research, it looks like silicone is ok as long as it is not exposed to sun light all the time.
