Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-25-2005, 07:35 PM
turbojusty turbojusty is offline
Send a message via MSN to turbojusty
what size engine do i have?
I picked up an 8cyl on the weekend. Its out of a 1979 Sportsman cube van, 3 speed auto. I was told it was a 318, but while browsing the internet looking for more info on the motor, someone said to look on the front left side of the block and thats where I can find the displacement. Well, the number on the block was this: 4006830-360-9....so, now i dont really know what that means, but if thats the number thats showing my displacement, i dont see a 318 anywhere in there...am i getting my hopes up for nothing here or do i have a 360 and not a 318??
thanx
mike
Old 10-25-2005, 08:43 PM
smithm smithm is offline
Re: what size engine do i have?
just figure out the litres if you can
Old 10-25-2005, 08:44 PM
if not then it might be a 318 more than likely
Old 10-26-2005, 03:05 AM
Blylock Blylock is offline
thanx
mike
i would hope for a 318
1998 Ram 1500 SLT 4x4
5.9L
Dynomax Performance Dual Exhaust
KN cold air intake
Bosch +4 Platnum Plugs
180 Degree Thermostat
I would suggest to anyone with a Ram to convert to a performance exhaust, especially if towing alot.
Old 10-26-2005, 07:43 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
If you're planning on tearing it apart, just measure the bore. 318 is 3.31", and 360 is 3.58".
http://www.allpar.com/mopar/318.html
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-26-2005, 12:19 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
as far as i can tell, you have a 360. the casting numbers are more specific than the stamped numbers with chrysler. imagine that. post casting numbers from block and heads
Old 11-06-2005, 08:42 PM
TurboDuck's Avatar
TurboDuck TurboDuck is offline
It sounds like you have a 360 - another way to tell is to look at the torque convertor. The 360 is an externally balanced engine, the convertor will have an extra weight welded on it if it's a 360. The front damper is different as well.
Good luck, Gary.
Old 11-08-2005, 04:52 PM
dadodgekid dadodgekid is offline
its definitely a 360 the last 4 casting numbers on the block will tell you this , which in fact, say -360-9 so you have a 360
